My type R cams or others? What is the best choice for my setup
Old Feb 22, 2008 | 04:26 PM
1998turboR's Avatar
Default My type R cams or others? What is the best choice for my setup
b18c5 bored to 84mm
cp piston 84mm
pauter rods
type r oil pump
all new gaskets
autometer guages oil pressure/egt/boost
new bearings
ARP head studs
exedy clutch
fidanza flywheel
new valvetrain
greddy boost controller
energy inserts
custom 3inch dp and exhuast with n1 muffler
precision turbo sc6163 with custom manifold
rc 1000cc injectors
golden eagle sleeves
hondata s200 w boost
BandM fuel pressure regulator
ngk plugs
tial wastegate
dumptube
intercooler from a drag kit
type r cams
toda cam gears Do i need these it was when i was NA
valve job
3 map bar sensor
koyo radiator
Old Feb 22, 2008 | 04:44 PM
ctr83's Avatar
Default Re: My type R cams or others? What is the best choice for my setup (1998turboR)
ya you can make some good ## on them cams.
Old Feb 22, 2008 | 04:45 PM
boostedcivicsir's Avatar
Mr. Badwrench
i made 520 on a b16 with gsr cams.
friend just made 650 with ctr cams and a 35r.
if you have them already, use them. plenty of power can be made with them.
punkracer
Dec 16, 2010 08:47 PM
highboostcivic
Jun 15, 2010 09:14 AM
lsvtechatchy96
May 26, 2007 10:53 PM
slowpokesi
Jun 28, 2004 05:50 PM
HondaRacer32
Jan 4, 2004 03:16 AM
