My type R cams or others? What is the best choice for my setup
b18c5 bored to 84mm
cp piston 84mm
pauter rods
type r oil pump
all new gaskets
autometer guages oil pressure/egt/boost
new bearings
ARP head studs
exedy clutch
fidanza flywheel
new valvetrain
greddy boost controller
energy inserts
custom 3inch dp and exhuast with n1 muffler
precision turbo sc6163 with custom manifold
rc 1000cc injectors
golden eagle sleeves
hondata s200 w boost
BandM fuel pressure regulator
ngk plugs
tial wastegate
dumptube
intercooler from a drag kit
type r cams
toda cam gears Do i need these it was when i was NA
valve job
3 map bar sensor
koyo radiator
cp piston 84mm
pauter rods
type r oil pump
all new gaskets
new bearings
ARP head studs
exedy clutch
fidanza flywheel
new valvetrain
energy inserts
rc 1000cc injectors
ngk plugs
tial wastegate
dumptube
type r cams
valve job
3 map bar sensor
koyo radiator
Mr. Badwrench
Re: My type R cams or others? What is the best choice for my setup (1998turboR)
i made 520 on a b16 with gsr cams.
friend just made 650 with ctr cams and a 35r.
if you have them already, use them. plenty of power can be made with them.
