CRX B16 Idles High
Old Feb 22, 2008 | 04:01 PM
Bonestock98GS's Avatar
Default CRX B16 Idles High
Hey guys I did a search and this was the closest thing I could find pertaining to my question. https://honda-tech.com/zerothread?id=1804778
See I have a CRX with a B16 i am going to buy tomorrow and it idles perfect when you start it but when it get warm it idles high and then low for a good amount of time. The guy said he checked everything that had to do with vacuum. But it continues to do it. do you think it could be TPS?
Old Feb 22, 2008 | 06:56 PM
KrenzyRyan's Avatar
Default Re: CRX B16 Idles High (Bonestock98GS)
Best idle solving site ever: http://www.ef-honda.com/ben/Badidle.php
GL
Old Feb 22, 2008 | 08:11 PM
Default Re: CRX B16 Idles High (KrenzyRyan)
Thanks man I am going to be picking the car up tomorrow and I wanna get that kink out thats a nice site too
Old Feb 22, 2008 | 08:21 PM
traxxasx's Avatar
with out even seein the car is the FITV shops couldent fix these cars, i looked at it its the FITV on all the cars i did it to. Dont waste ur time on other ****.
The white vavle inside has came loose. tighten it back down inside problem solved.
Old Feb 22, 2008 | 09:04 PM
vtec93accord's Avatar
Yep, ive seen this problem as well, FITV for sure.
Old Feb 22, 2008 | 09:51 PM
Default Re: (vtec93accord)
Ok where do I find this white valve tho. I see on the diagram where its Highlighted FITV but how do I get to it??? Do I open up the FITV?
Old Feb 25, 2008 | 04:11 PM
Default Re: (Bonestock98GS)
Ok its not the FITV cuz I went and tightened that down tonight. I took my intake off and put my finger over the FITV hole and when it idled down thats when it sucked it didnt suck idling up. I tampered with the Idle screw also. I dont know what else could be the cause. It warms up and then idles high and low until you cut the car off. I need advice badd. And the guy I bought it from said he checked everything vacuum wise
Old Mar 5, 2008 | 11:55 AM
Ok I checked and cleaned my IACV valve. I sprayed around all my hoses and gaskets to check for an vacuum leak. I tightned down the FITV valve and this [freak]in car still idles high. INEED HELP ASAP. and now a new problemwith the car happened. The first time I cranked it it started but it also acted like it didnt wanna crank. I shut it off and went back to crank it and it wanted to turn over but didnt. Sometimes it wanted to turn over and the rest it didnt the starter just clicked. Now what is wrong wit it now. My dad says the battery isnt getting a charge. The Battery is relocated also.
Old Mar 5, 2008 | 12:43 PM
Bumpity Bump
Old Mar 5, 2008 | 01:23 PM
sgallagher's Avatar
As for the no start. Just charge your battery. If you're not driving the car but keep starting it to find the idle problem then the batttery is going to get discharged pretty quick.
Old Mar 5, 2008 | 01:26 PM
Default Re: (sgallagher)
Thanks I am charging the battery right now lol. I am trying to sit on here and search what else could be the problem. I am going to cjeck for the air bubbles in the coolant next. Now if I dont have a coolant drain plug whats the best way to go bout draining the coolant?
louisiana CRX
Dec 1, 2008 05:37 PM
davidcrx89
Apr 25, 2005 03:12 PM
