bad piston rings???how can tell??
Old Feb 22, 2008 | 03:01 PM
ONE*SICK*FERIO's Avatar
Default bad piston rings???how can tell??
my car is burning oil i know it could be valve steam seals or pistong rings
but whats the best way to tell that the rings are bad????
1._leak down test ,
2._compression test ,
3._can't tell untill you re-build the block
thanks
Old Feb 22, 2008 | 04:03 PM
Lewy. Dee Ayy's Avatar
Default Re: bad piston rings???how can tell?? (ONE*SICK*FERIO)
compression test
write down numbers
add a few drops of oil to each cyl
redo compression test
if they numbers go up ALOT
id say your rings are going bad.
Old Feb 22, 2008 | 09:29 PM
Default Re: bad piston rings???how can tell?? (Lewy. Dee Ayy)
uumm.....hey Lewy. Dee Ayy that sounds good
i'll do that and let u know what happend
thank you sir!!!
Old Feb 22, 2008 | 11:39 PM
clockwork675's Avatar
another way imo for a quick reference is does it brn oil on tartup really bad? if it is valve seals are probably bd, burns under rpm rings, thats just in my experience though
Old Feb 23, 2008 | 11:22 AM
bjones's Avatar
Default Re: (clockwork675)
cylinder leakage test is good way to figure that out, if u dont really feel air coming out but it shows high leakage, feel around the crankcase, if u feel some air then, prolly bad rings
Old Feb 23, 2008 | 06:08 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clockwork675 &raquo;</TD></TR><TR><TD CLASS="quote">another way imo for a quick reference is does it brn oil on tartup really bad? if it is valve seals are probably bd, burns under rpm rings, thats just in my experience though</TD></TR></TABLE>
no smoke on start up just after vtec kick on
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bjones &raquo;</TD></TR><TR><TD CLASS="quote">cylinder leakage test is good way to figure that out, if u dont really feel air coming out but it shows high leakage, feel around the crankcase, if u feel some air then, prolly bad rings</TD></TR></TABLE>
i did that and it was fine just 3psi lost
HERE IS WHAT I FOUND TODAY!1!
I TURN ON THE CAR POP UP THE HOOD AND PULL THE TROTLE CABLE
REVING THE ENGINE AROUND 4500 RPM-7000 RPM AND SAW A LOT OF SMOKE COMING OUT FROM THE BACK OF THE ENGINE ON THE ALTERNATOR AREA UNDER THE MANIFOLD I COULDN'T FIND EXACTLY WHERE BUT ILL KEEP AND EYE ON IT. NOW I CAN UNDERSTAND HOW THE SMOKE IS GETTING INSIDE . I'M SURE IS NOT AIR LEAK FROM THE EXHAUST.
WHAT IT COULD BE???
Old Feb 23, 2008 | 09:31 PM
if its not coming out the exhaust it could be cam seals leaking into timing belt cover, look for oil leaks where oil might be burning off the block from leak
Old Sep 26, 2010 | 08:28 PM
unknownally's Avatar
So what happened?
Old Sep 26, 2010 | 08:36 PM
racebum's Avatar
as usual the guides are overlooked even though they are often a major cause of oil burning.
Old Sep 27, 2010 | 10:22 AM
vtecdc4's Avatar
Originally Posted by Lewy. Dee Ayy
compression test
write down numbers
this
jc2801
27
Aug 25, 2015 08:22 PM
silverboost
Nov 8, 2005 01:01 PM
mike93eh
21
Sep 18, 2005 12:23 PM
S2KP
Oct 24, 2003 03:39 AM
Black DC2
Nov 8, 2002 08:36 PM
