Honda S2000 Honda S2000
Coilovers too low...
Old Feb 22, 2008 | 01:06 PM
alexisthemovie's Avatar
Default Coilovers too low...
Ok so I just had my buddy club n+ installed and the front ones are set all the way high and it is slammed and tucking tire.
I lowered it about 10 threads in back (about 2 inches) and the front barely raised up. I still have like 4 inches of thread on the coilover in front and about 3 inches left in back...I don't think they were installed wrong. Are there 2 mounting perches or something (a high and low one)?
No pics yet. I was going to slam it anyways, but not this low.
Old Feb 22, 2008 | 01:19 PM
s2kdre's Avatar
Default Re: Coilovers too low... (alexisthemovie)
make sure theres zero preload on the spring. because u can adjust the height with the spring and the shock body.
Old Feb 22, 2008 | 01:38 PM
Default Re: Coilovers too low... (s2kdre)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s2kdre &raquo;</TD></TR><TR><TD CLASS="quote">make sure theres zero preload on the spring. because u can adjust the height with the spring and the shock body.</TD></TR></TABLE>
Does that mean adjust it in the air? They were all adjusted on a lift.
Old Feb 22, 2008 | 01:43 PM
b20integrapower's Avatar
Are you sure you arent thinking things backwards? This sound stupid, but are the perches closer to the ground or towards the top hats? Again that sounds really dumb, but this whole thing doesn't make any sense.
Old Feb 22, 2008 | 01:45 PM
i didn't watch the install so I don't know. Is there a high and low perch?
Old Feb 22, 2008 | 01:50 PM
Default Re: (alexisthemovie)
Let me go find a picture of you particular setup. But if the perches are closer to the ground, then you are just slammed. You needa raise them. hold up.
GRAF-FITI's Avatar
* B A N N E D *
are they set up like these?
http://www.s2ki.com/forums/ind...63927
Old Feb 22, 2008 | 01:52 PM
Default Re: (b20integrapower)
Okay well go out and check if the perches are all the way at the base of the shock. I bet you have the perches all the way down.
Old Feb 22, 2008 | 01:53 PM
Default Re: (GRAF-FITI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAF-FITI &raquo;</TD></TR><TR><TD CLASS="quote">are they set up like these?
http://www.s2ki.com/forums/ind...63927</TD></TR></TABLE>
yes
Yeah check out the link graf got for you. That car is probably flyin btw. haha
Old Feb 22, 2008 | 01:54 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alexisthemovie &raquo;</TD></TR><TR><TD CLASS="quote">
yes</TD></TR></TABLE>
alright..well see how the perches are sorta in the middle and towards the top? well i bet your fronts are slammed all the way down. Iono..go look.
Old Feb 22, 2008 | 01:55 PM
Well if you lowered the back you obviously know what a perch is and what lowering with coilovers entails...so im assuming there might really be somethin wrong. Snap some pics for us.
Old Feb 22, 2008 | 01:57 PM
the fronts are all the way UP. the backs are 10 turns down.
Old Feb 22, 2008 | 01:59 PM
when I got back to work, my frame and exhaust dragged on the pavement because there's a hump over the driveway.
Old Feb 22, 2008 | 04:31 PM
wow..i dont know then. Take it back to the people who installed it and have them fix it.
Old Feb 22, 2008 | 07:16 PM
Black S2K's Avatar
This is why I install and do all the work to my car myself. Friends are great helpe if they know their **** just like you. I dont know I cant seem to trust total strangers with my car. The only way I would take my car to shop would be if one of my good friends worked there.
Old Feb 23, 2008 | 02:48 AM
my friend does work there and I'm cool with the owner/mechanic too. He has worked on all of my cars. I just thought there might be some odd step in the suspension install for s2k's?
I'm working full time and going to school full time so I can't install them myself.
Old Feb 24, 2008 | 08:14 PM
99_SH's Avatar
Since they're already installed, adjusting them shouldn't take too long. Make sure you have zero preload on the springs, and adjust the shock body for your ride height.
Old Feb 24, 2008 | 08:21 PM
Default Re: (99_SH)
i guess i'm just going to leave it at this height.
Old Feb 24, 2008 | 08:34 PM
wayyyy wayyy too low..i bet it handles like ish.
Old Feb 25, 2008 | 05:53 PM
emfollin's Avatar
Damn man, you are plowing pebbles at that height. I would definately snap a picture of your front setup. Something has got to be wrong. It sounds to me like the spring is preloaded.
Old Feb 25, 2008 | 06:05 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: (emfollin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by emfollin &raquo;</TD></TR><TR><TD CLASS="quote">Damn man, you are plowing pebbles at that height. I would definately snap a picture of your front setup. Something has got to be wrong. It sounds to me like the spring is preloaded.</TD></TR></TABLE>
If the spring was preloaded, it would be higher up. You probably have the bottom adjustment way too far down.
You're not supposed to touch the spring height. Adjust with the base of the coilover. You're essentially bringing the suspension upwards or pushing it downwards instead of reducing shock travel.
Do this: Adjust both ends so that the spring is at the normal height. NOT preloaded/crushed, not not hanging down. The spring perches need to be set at full shock travel.
Jam those perches together so they wont move.
Loosen the BOTTOM perch. Grab the entire shock body or the spring. Turn the entire shock body counterclockwise to raise it up. Clockwise to bring it down.
The springs will settle with time....the car could get like .25'' lower.
Take it to another place if you dont know what I'm talking about. I hope he clocked your bushings after putting it that freaking low.
Modified by B serious at 10:05 PM 2/25/2008
Old Feb 25, 2008 | 08:36 PM
AP1 John's Avatar
let me have them for my stock and it will fix everything
Old Feb 25, 2008 | 08:57 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B serious &raquo;</TD></TR><TR><TD CLASS="quote">
Ah, I see what you are saying. They lowered it by "crushing" the spring so I guess we'll take a look at it again tomorrow.
Old Feb 25, 2008 | 09:40 PM
B serious's Avatar
Ah, I see what you are saying. They lowered it by "crushing" the spring so I guess we'll take a look at it again tomorrow.</TD></TR></TABLE>
No. If they crushed the spring, it would be higher up. They lowered it by adjusting the spring perch and letting it droop.
You need to have the spring at "stock" height. Know what I mean? Have the top of the spring touching the top mount, and have the spring perches JUST slightly having tension on the spring. JUST SLIGHTLY.
Then adjust the base of the coilover to raise or lower it.
Clock the bushings. Get an alignment.
