horn relay, sunroof switch and driver side window switch click
Old Feb 22, 2008 | 10:46 AM
thegreensnail's Avatar
Default horn relay, sunroof switch and driver side window switch click
hi, i own a 95 civic coupe EX, lately i had problems with horn, sunroof and left electric window not working sometimes, i got a back problem due to car accident but i tried gettin under the steerinwheel to check the fuses also check under hood, they all seem fine...when horn doesnt work theres a click under the steeringwheel, well i unplugged the relay to pull it out but couldnt really see it and didnt want to brake it (how u pull it out?) well it works sometimes, the sunroof clicks and wont open but works if i give it a push and doesnt click, also left side window goes down normal but is really slow going up...i cleaned the contacts on the switch cause it wouldnt go up and clicked(it worked)...whats that clickin on the window switche?...i would test them when im good, but would like to see others opinions....thanks and sorry for the not soooo short expanation but i hope i was clear enough...ohhh before i forget i think my IAC valve is bad...idle is usually between 800 to 2k RPM...should i replace it or how u test it and finally how much is it to buy?....95 JDM b18c1 swap almost 3 years old 83k miles.... ppl says IAC goes bad in HONDAs if usually rev them too high...true or not?
dirtridernathan
12
Jun 29, 2013 10:32 AM
MikesEJ1
Jun 2, 2012 07:12 PM
v-tecnition
Oct 6, 2008 01:19 PM
drew and not u
Jun 28, 2008 06:56 PM
BACKintheDA
Apr 18, 2004 04:05 PM
