Drum to disk confussion... Eg disks onto my 00 ek hatch
Old Feb 22, 2008 | 10:05 AM
Dr. Willy's Avatar
Default Drum to disk confussion... Eg disks onto my 00 ek hatch
Ok i searched and read through a lot of information, including the X brakes onto my 96-00 civic post, which had a lot of great information. Im pulling brakes out of a 4dr ex eg with abs. Now i know that i use my same lower control arms and upper control arms, but (from what i understand of it) i need 99-00 si ebrake cables, brake fluid lines, and prop valve? Is this correct or will all the one's off the call im pulling it from work. Also im assuming that the abs lines will do me no good seeing how my car never came with abs
Old Feb 22, 2008 | 10:09 AM
IIXtremeHansen's Avatar
Default Re: Drum to disk confussion... Eg disks onto my 00 ek hatch (Dr. *****)
Your right . I did the swap also. get SI Master,E-Cables, and the Prop. No Lines Needed if your pulling the whole thing with the lines.
Have them on mines and im pleased.
Modified by Dickies_n_FlipFlops at 12:34 PM 2/22/2008
Old Feb 22, 2008 | 10:14 AM
Dr. Willy's Avatar
Default Re: Drum to disk confussion... Eg disks onto my 00 ek hatch (Dickies_n_FlipFlops)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dickies_n_FlipFlops &raquo;</TD></TR><TR><TD CLASS="quote">Your right . I did the swap also. get SI Master,E-Cables, and the Prop. No Lines Needed if your pulling the whole thing with the lines.</TD></TR></TABLE>
I need master too? i though all 96-00 ek's use the same MC
Old Feb 22, 2008 | 10:19 AM
smileycvc's Avatar
You dont have to have the MC and prop vavle, but the pedal might feel a little mushy. I never switched mine when I did my conversion and its no big deal.
Malakai's Avatar
From what i know, the only really "needed" component is the e-brake cable.
Old Feb 22, 2008 | 10:21 AM
ek4_b16a's Avatar
Default Re: (Malakai)
^^yes, all you need is the e-brake cable and that's it...oh yea and new brake lines while you're at it!
Old Feb 22, 2008 | 10:22 AM
All 96+EX/SI Same. DX Prop and MC is diffrent. if you want good braking get the ex or si.
Dr. Willy's Avatar
do you think the prop valve out of the car im taking the brakes off of would be better then my stock one, and i was gonna get a MC just not right at this moment. I dont want my pedal to feel "Mushy". i do take the car out to the track pretty often.
Old Feb 22, 2008 | 10:27 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dickies_n_FlipFlops &raquo;</TD></TR><TR><TD CLASS="quote">All 96+EX/SI Same. DX Prop and MC is diffrent. if you want good braking get the ex or si.</TD></TR></TABLE>
Actually, the DX shares the same Brake Booster and Prop valve as the 99-00 Si.
All the Original Poster needs are the e-brake cables (99-00 Si), I wouldn't upgrade the MC until you upgrade the front brakes.
Old Feb 22, 2008 | 10:29 AM
Dr. Willy's Avatar
Default Re: Drum to disk confussion... Eg disks onto my 00 ek hatch (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">
All the Original Poster needs are the e-brake cables (99-00 Si), I wouldn't upgrade the MC until you upgrade the front brakes. </TD></TR></TABLE>
Thats what i like to hear haha. ok so i guess i will just order ebrake cables
Old Feb 22, 2008 | 10:49 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr. ***** &raquo;</TD></TR><TR><TD CLASS="quote">
Thats what i like to hear haha. ok so i guess i will just order ebrake cables</TD></TR></TABLE>
Do you not want to upgrade the front brakes? I am just asking because it is a perfect upgrade with a noticeable difference especially after getting the 99-00 Si MC. This way you only need to go through the trouble of bleeding the brakes once.
Old Feb 22, 2008 | 01:08 PM
Dr. Willy's Avatar
Do you not want to upgrade the front brakes? I am just asking because it is a perfect upgrade with a noticeable difference especially after getting the 99-00 Si MC. This way you only need to go through the trouble of bleeding the brakes once. </TD></TR></TABLE>
no i dont, least not right now, no funds for it, plus idk what kind of kit i would use.
Old Feb 22, 2008 | 02:11 PM
EL Vap133's Avatar
no i dont, least not right now, no funds for it, plus idk what kind of kit i would use.</TD></TR></TABLE>
Actually you'll be set with a 99-00 Si front brake set up which is less expensive than you think. Usually they go for about $175-$250 if at that. I did this to my hatch and sedan and love the improvement.
my74honda
Suspension & Brakes
Jan 14, 2013 04:23 AM
95_GSR_SEDAN
29
Nov 15, 2009 12:21 PM
civicseth
Jan 4, 2007 10:47 PM
phateless
Nov 28, 2005 07:40 AM
WildPig
10
Apr 25, 2005 02:17 PM
