WTB: Used Rod/Main Bearings
I am in need of some rod & main bearings from a GSR (or any others that will work)...
I didn't realize that I'd need the old ones when I disassembled my engine...
I shipped the rod bearings out with my old pistons & rods when I sold them, and I don't know what the frigg I did with the main bearings...
I need them to size the new ones, so who's got some?
Used bearings aren't usually worth a hell of a lot, so I'd be willing to pay less than a hell of a lot...
y not just code out the bearings from using the code on the block, crank,rods (if u remember what they are)? otherwise u can mic. everything and use the bearing size chart from Laskeyracing.com to get the colors u need
Why would you even use the old bearings??? That is something that i would never do. Go with the factory bearings or ACL. If im not mistaken if you go with aftermarket rods you would use brown factory honda bearings. I could be wrong. It's been awhile since if done a motor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1fastvik »</TD></TR><TR><TD CLASS="quote">Why would you even use the old bearings??? That is something that i would never do. Go with the factory bearings or ACL. If im not mistaken if you go with aftermarket rods you would use brown factory honda bearings. I could be wrong. It's been awhile since if done a motor</TD></TR></TABLE>
Jesus.. Don't people even read anymore?
As stated above, I need them to size the new ones before I purchase them. And no, you cannot arbitrarily use brown with aftermarket rods. You need to properly size them using the old bearings & plastigage.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tricura »</TD></TR><TR><TD CLASS="quote">Put ACL's in it, you won't have to do anything.</TD></TR></TABLE>
DO IT.
DO IT.
