Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Different suspension squeak
Old Feb 22, 2008 | 08:11 AM
K24_Y61P's Avatar
Default Different suspension squeak
Searched for a while and haven't found anything that covers my problem. My suspension squeaks when I go over a series of bumps, and when I turn the wheel. I took the wheel off, flushed all the dirt out. I re-greased the problem strut with white lithium grease. I drove it some more and the problem still exists. I'm running Tein Basic coil overs. I've been thinking it's the cold stiffening the rubber, but it is warmer today and it is still there. What do you guys think it is or how could it be fixed? I hate driving around with a loud squeak with people outside it. Giving our Honda's a bad name.
Old Feb 22, 2008 | 09:39 AM
toyomatt84's Avatar
Sanji
It might be your compliance bushings.
Old Feb 22, 2008 | 09:43 AM
K24_Y61P's Avatar
Default Re: (toyomatt84)
and the way to fix it? <crosses fingers>
Old Feb 22, 2008 | 09:47 AM
toyomatt84's Avatar
Sanji
Default Re: (ajgrosch716)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ajgrosch716 &raquo;</TD></TR><TR><TD CLASS="quote"> and the way to fix it? &lt;crosses fingers&gt;</TD></TR></TABLE>
Removing LCA's from sub-frame and hub, and getting them pressed out.
Old Feb 22, 2008 | 12:12 PM
LatinEM2's Avatar
1. Raise the vehicle on a hoist, then remove the front wheel from the appropriate side of the vehicle.
2. Remove the lower control arm from the vehicle. Refer to page 18-19 of the 2001-04 Civic Service Manual.
*NOTE: Use the Ball Joint Thread Protector (T/N 07AAF-SDAA100) and the Ball Joint Remover (T/N 07MAC-SL00200) when disconnecting the ball joint from the lower arm. Do not use a hammer to loosen the ball joint.*
3. Mark the position of the arrows on the old compliance bushing onto the lower control arm.
4. Using a hydraulic press, the compliance bushing driver, and the compliance bushing receiver, remove the old compliance bushing. Discard the bushing.
5. Clean the inside of the bushing mating surface on the lower control arm.
6. Align the arrow marks on the new compliance bushing with the marks you made on the lower control arm. Using a hydraulic press, the compliance bushing driver, the compliance bushing receiver, and the spacer ring, press the bushing into the arm. The bushing will stop when it contacts the spacer ring.
7. Install the lower control arm onto the vehicle. Refer to page 18-19 of the service manual.
8. Check the wheel alignment, and adjust it if necessary. Refer to page 18-4 of the service manual.
Old Feb 23, 2008 | 04:19 AM
K24_Y61P's Avatar
Default Re: (LatinEM2)
Thanks for all the great information. But I still don't think that its the bushing. I don't think the bushing moves as far as the squeak lasts. It still seems like the strut to me...
Old Feb 24, 2008 | 06:03 PM
K24_Y61P's Avatar
Yup, defiantly the compliance. I'm getting http://www.clubrsx.com/cr/PCI-....html to fix it, hopefully permanently.
Old Feb 24, 2008 | 07:46 PM
LatinEM2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ajgrosch716 &raquo;</TD></TR><TR><TD CLASS="quote">Yup, defiantly the compliance. I'm getting http://www.clubrsx.com/cr/PCI-....html to fix it, hopefully permanently. </TD></TR></TABLE>
I also have to do mine, tell me how you like those and how easy the installation is.
Old Feb 25, 2008 | 04:49 AM
K24_Y61P's Avatar
Lol, the install will be easy. I'm taking it to a shop. I'll be sure to let you know how they are when they are in.
Old Feb 25, 2008 | 06:03 AM
LatinEM2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ajgrosch716 &raquo;</TD></TR><TR><TD CLASS="quote">Lol, the install will be easy. I'm taking it to a shop. I'll be sure to let you know how they are when they are in.</TD></TR></TABLE>
How much is the install going to be?? One shop here wanted 249 just labor
Old Feb 25, 2008 | 06:14 AM
Harlowe's Avatar
Function>Fashion
My rear suspension squeaks. All my friends told me it was a blown strut, but I know blown struts dont sound like that...
Once I get the car back from the bodyshop I will be figuring out what the squeak is coming from.
Old May 27, 2008 | 10:46 AM
oddmut's Avatar
Default Re: (Harlowe)
where to get:
Ball Joint Remover
compliance bushing receiver set
isn't there like another way to pop the ball joint apart but using like a rachet and put it between to lower control arm and the arm of the ball joint and the twist the rachet and it pops it?
edit: maybe not the kicking part http://www.youtube.com/watch?v=ISY8bGof3bQ.
Modified by oddmut at 11:59 AM 5/27/2008
Old May 27, 2008 | 10:59 AM
ballinboosi's Avatar
Default Re: (oddmut)
Octanum
Feb 28, 2012 12:14 PM
el3men2_4dr
Suspension & Brakes
Jul 20, 2007 06:41 AM
WTB AUTO EK
Jan 4, 2006 12:31 PM
civic97pr
Nov 19, 2005 04:54 AM
