Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Recommended hose size for oil cooler? -8 or -10
Old Jul 5, 2002 | 10:30 AM
Steve91's Avatar
Default Recommended hose size for oil cooler? -8 or -10
Is -10 overkill?
Old Jul 5, 2002 | 11:39 AM
Warren's Avatar
Wrong-Way Wang
Default Re: Recommended hose size for oil cooler? -8 or -10 (Steve91)
I use -10. Works great. No noticable loss in oil pressure. I'm over 80 psi above 3500 rpm.
Warren
Old Jul 8, 2002 | 07:28 PM
N24RE's Avatar
I think -10 is THE way to go...I use it in mine...no problems at all...pressures are A OK.
Look in my sig for pics of the install.....I was at VIR this weekend in 95+ air temps...oil stayed below 250 degrees....I was VERY happy with that.
Cheers'
Old Jul 9, 2002 | 01:03 AM
TurBoXBirD16's Avatar
Default Re: Recommended hose size for oil cooler? -8 or -10 (N24RE)
is a oil thermastat needed with an oil cooler??
Old Jul 9, 2002 | 06:10 AM
Warren's Avatar
Wrong-Way Wang
Default Re: Recommended hose size for oil cooler? -8 or -10 (xbird)
Not on a track car. Just use cardboard to block part of it off if it's too effective in cold weather.
An oil thermostat is just another thing that can go wrong.
Warren
Old Jul 9, 2002 | 06:17 AM
Default Re: Recommended hose size for oil cooler? -8 or -10 (Warren)
so a thermastate helps the car starting in cold weather?
Old Jul 9, 2002 | 08:03 AM
Geezer's Avatar
Not really. It keeps the oil at the best operating temperature (around 100 deg. c), by routing it to the cooler if it's too hot, or bypassing the cooler if it's too cool. If the oil gets too cool, it gets more viscous (thicker) and robs power. If it gets too hot it doesn't lubricate any more.
Old Jul 9, 2002 | 08:38 AM
Default Re: Recommended hose size for oil cooler? -8 or -10 (Geezer)
oh ok thanks
it just acts like an coolant thermastat
so would it cost any problems to start if the weather is like - 25 degrees out side??
Old Jul 9, 2002 | 09:44 AM
Track rat's Avatar
Like Warren said, just eliminate air blowing directly at the cooler in cold weather with duct tape or cardboard and you'll reach normal operating temps. Cover it in winter, uncover it in summer.
Go with -10 hose.
[Modified by Track rat, 6:45 PM 7/9/2002]
Old Jul 9, 2002 | 09:49 AM
Default Re: Recommended hose size for oil cooler? -8 or -10 (Track rat)
hehe, if ur car is running which means it's already started, does it matter?? will the car stall if the oil temp goes down?
i was just saying STARTING the car when i wake up in the morning.. hehehe
so cardboard or not, doesn't matter
Old Jul 9, 2002 | 10:08 AM
Track rat's Avatar
If your car sits over night in cold temps, the oil will likely be the same temp at start up regardless if you have a cooler or not. A good synthetic oil will still flow well in cold temps through the cooler, lines and engine at start up.
The concern lies in driving around town with a warm engine and overcooled oil, covering up the cooler helps prevent this. Cold, thick, viscous oil will not flow as well to vital parts at high RPMs. This is why VTEC is programmed not to engage if your oil (or coolant) is too cold. Most engines like 180 - 200 degree oil. Synthetics claim good protection up to 300 deg, but most racers like to keep it under 250, hence the need for auxillary coolers if you run it at track events or race it.
[Modified by Track rat, 7:18 PM 7/9/2002]
[Modified by Track rat, 7:20 PM 7/9/2002]
Old Jul 9, 2002 | 10:16 AM
YodaIsGod
Guest
Posts: n/a
anyone remember this?
http://www.sonic.net/~abwc/jeff/heat/oilcooler.html
Old Jul 9, 2002 | 10:48 AM
Warren's Avatar
Wrong-Way Wang
Default Re: Recommended hose size for oil cooler? -8 or -10 (YodaIsGod)
That's Adrian Teo's setup, and it's the basic layout that used, because he was smart and used straight AN fittings. I don't like that oil cooler though.
Warren
Old Jul 11, 2002 | 06:49 PM
N24RE's Avatar
Dude...if this is a street car....just get a thermostat...especially if you are in -25 degree weather. A good thermostat will only add about 50 bucks to your install. My install is a WORST case as far as price goes. I put a stat on mine so I could just get in and drive and not have to deal with card board or anything. Now I agree with Warren 100%...if it is a race car don't bother with a stat.
BUT I get the impression this is your driver/racer
just my 2 cents
Old Jul 11, 2002 | 08:42 PM
Steve91's Avatar
Thanks for the tips guys. The car is race only and I live in So. Cal so I will probably skip the thermostat. I think I'm going to go with a Mocal or Setrab cooler and definately -10 lines.
Old Jul 12, 2002 | 07:55 AM
WOTTEG's Avatar
Both of these statements are incorrect!
I think you two have misunderstood oil viscosity. Oil viscosity is it's thickness, or "strength".
Oil viscosity reatings:
0-30W
5-30W
10-30W
The first # indicate the viscosity at low tempuratures, the second # indicates the viscosity at operating tempersture.
So 5-30W has a lowest viscosity of 5, and it's highest voscosity is 30.
Thus, As engine oil heats up, its viscosity rises, which means IT GETS THICKER.
There are two reasons for this:
1) As the enigne starts, a thinner viscosity is needed to quickly deliver the oil to moving parts.
2) As the heated moving parts expand and increase their lubrication needs, the oil becomes more viscous (thicker), which promotes a more impregnable layer or "film" that forms in between the parts.
All of this is documented in August's issue of Hot Rod Magazine. The back of an oil container may even explain this.
Just trying to staighten things out here, I mean no disrespect.
Old Jul 12, 2002 | 04:30 PM
Gansan's Avatar
Default Re: Recommended hose size for oil cooler? -8 or -10 (WOTTEG)
I don't think you are right on that. All oils get thinner as they get warmer. The viscosity rating that shows oil getting a higher viscosity at higher temperatures means that it gets less thin, not that it gets thicker. Similarly, if the oil is rated to be lower viscosity at low temps, that means that it doesn't thicken as much as it normally would, but it does still get thicker.
If oil got thicker as it got hotter, then your oil pressure guage would show higher pressure as you warmed up, but that is definitely not the case. Oil pressure drops a lot as you warm up. And doing an oil change when the oil is warm is because it will flow better, not because it is getting thicker and flowing less.
[Modified by Gansan, 5:33 PM 7/12/2002]
Old Jul 12, 2002 | 10:43 PM
Floyd's Avatar
Default Re: Recommended hose size for oil cooler? -8 or -10 (Gansan)
Motor oil is a liquid, just like any other, and when it gets hotter, it gets thinner, and when it gets colder, it gets thicker. As the oil cools down, the molecules become less energetic, and start to slow down, resulting in a fluid that will not poor well. Eventually, if the temp drops low enough, the oil would freeze, just like any other liquid, and it would stop moving all together.
However, I would agree that the viscosity rating on the container may lead someone to this backwards conclusion.
BTW, would one also recommend a -10 line for a remote oil filter as well?
wantboost
Feb 24, 2013 02:13 AM
brainwo
Oct 2, 2003 04:14 PM
SiRkid
Sep 22, 2002 03:26 PM
pinota
Aug 22, 2002 07:14 PM
Batoutahell
Jul 9, 2002 12:29 PM
