Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
When should I change my front brakes - 23K miles?
Old Feb 22, 2008 | 07:24 AM
justin809's Avatar
Default When should I change my front brakes - 23K miles?
I thought my brakes were grinding so I took them to my mechanic and he said I shoud replace them. Does that sound right for a car with 23k miles on the factory brakes?
Old Feb 22, 2008 | 07:31 AM
RICO_'s Avatar
NO MERCY!
Default Re: When should I change my front brakes - 23K miles? (justin809)
I have 30K miles on my car and my brakes are just fine. Plenty of pad left. It all depends on how you drive your car. If you're in alot of stop and go traffic....you might need them replaced. But 23K seems a little early if you're not too aggressive with your car.
If he thinks your brakes are low....have him show them to you so you can see for yourself. Don't just take his word for it.
Old Feb 22, 2008 | 07:51 AM
SIVIC 3's Avatar
even though brake pads are super inexpensive, id still make him show em to me before having them replaced. well said RICO_
Old Feb 22, 2008 | 07:53 AM
justin809's Avatar
Default Re: (SIVIC 3)
Thanks for the advice!
Old Feb 22, 2008 | 12:47 PM
CerealKiller's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by justin809 &raquo;</TD></TR><TR><TD CLASS="quote">I thought my brakes were grinding so I took them to my mechanic and he said I shoud replace them. Does that sound right for a car with 23k miles on the factory brakes?</TD></TR></TABLE>
I have this same problem. front brakes have been grinding for the past month. I really don't drive my fg hard. I checked the brake pads, but both still have the padding in good condition. any suggestions?
Old Feb 22, 2008 | 01:01 PM
Perfectionist's Avatar
Brake pads are one of those things you can't cheat on. Either they are worn down, or they have life left. The thickness of the remaining material determines that. And, if the system is operating properly, there are wear indicators built into the pads that will squeal loudly when they get too worn.
That said, the rotors on my Acura suck. Any wetness still on them after I park the car will result in either stuck pads, (a nice clunk when I first move the car), or nasty grinding noises until I wear off the layer of rust during the first few stops.
k3ntegra
May 19, 2015 04:56 AM
wangan
Honda Civic (2001 - 2005)
Jun 27, 2008 10:43 AM
06 Habanero-NaVi
14
Feb 4, 2007 12:51 AM
C_I_V_I_C
15
Jun 4, 2003 03:33 PM
NoSpeed
Sep 5, 2001 03:01 PM
