Car shakes when braking at 55 - 70 MPH.
Old Feb 22, 2008 | 06:38 AM
deklao's Avatar
Default Car shakes when braking at 55 - 70 MPH.
Why my 91 Accord EX shakes when braking at 55 - 70 MPH? At low speed, it brakes smoothly. I just got 4 wheels balancing 1 weeks ago and changed my rotor 2 weeks ago.
Old Feb 22, 2008 | 06:44 AM
rirc's Avatar
Default Re: Car shakes when braking at 55 - 70 MPH. (deklao)
your brake discs are warped.
Old Feb 22, 2008 | 06:54 AM
Smasherguy18's Avatar
could be only your pads are out. Also could be discs.
Old Feb 22, 2008 | 10:13 AM
deklao's Avatar
I just replace brand new OEM discs and pads 2 weeks ago. Discs can't be warped. Pads can't go bad that fast.
Old Feb 22, 2008 | 02:52 PM
95-Accord-EX's Avatar
Default Re: (deklao)
i would just take it back to a shop or take it all apart to make sure everything is in working order
Old Feb 22, 2008 | 07:24 PM
flight50's Avatar
Default Re: (95-Accord-EX)
braking system, need wheel alignment, worn tires, suspension parts. you will more than likely find your culprit within on or more of the listed.
Old Feb 23, 2008 | 06:14 PM
chasnsx's Avatar
Worn caliper spring clips can cause that problem. Did they replace the spring clips or reuse the old ones?
Old Feb 23, 2008 | 08:45 PM
deklao's Avatar
I changed my own brake rotor and pads. I reused the old spring. I will go back and check it.
Old Feb 23, 2008 | 11:44 PM
Jmumblez2001's Avatar
check your balljoints or have the shop do it
Old Feb 24, 2008 | 05:57 AM
Chiovnidca's Avatar
Have you checked the rotors for runout and parallelism?
Old Feb 24, 2008 | 07:57 AM
Ronin1's Avatar
When you replaced the pads, were they evenly worn or was one worn much more than the rest?
It is possible that something is sticking, either a piston in the caliper or some other moving part of the caliper assembly (sorry, I don't remember just which caliper assembly your car has).
New does not necessarily mean "good". It is possible that the new rotors have a problem so check them for runout to be sure.
There was a suggestion to check ball joints. While doing that do not forget to check the tie rod ends as they can be a source of trouble also.
Good Luck
Old Feb 24, 2008 | 03:24 PM
tomatocity's Avatar
If the shake was also at low speed I would say replace the rotors.
Torque your wheels or remove the wheels and check for ANY debris between teh wheel and rotor. Reinstall the wheels and torque your wheels.
jonyi27
Aug 30, 2013 11:49 PM
jjohn6438
Honda Civic (2001 - 2005)
32
May 11, 2009 05:43 PM
swag
Apr 13, 2009 06:44 AM
blkbeast
Jan 14, 2002 12:58 PM
Quick 200k Mile Motor
13
Jan 11, 2002 10:43 PM
