Question on JDM p73 Ecu
Old Feb 21, 2008 | 11:18 PM
BoostedH's Avatar
Default Question on JDM p73 Ecu
Im going to be running a jdm p73 on my type r set up, did the jdm type r have a/c hooked up to the ecu? I think it did, i just dont want to lose my ac by running this ecu.Thanks!
Old Feb 22, 2008 | 06:58 AM
Relic1's Avatar
A/C works the same as the USDM counterpart.
Old Feb 22, 2008 | 02:47 PM
CRVRX's Avatar
Default Re: (Relic1)
We have a couple of these ECUs, Both of the ones we have require you to jump the AC controls in the ECU for it to work.These are 98 ECUs if that helps you any.
Old Feb 22, 2008 | 07:18 PM
Relic1's Avatar
Default Re: (CRVRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRVRX &raquo;</TD></TR><TR><TD CLASS="quote">We have a couple of these ECUs, Both of the ones we have require you to jump the AC controls in the ECU for it to work.These are 98 ECUs if that helps you any.</TD></TR></TABLE>
mmm, maybe the 00-01 is different in that aspect. I've tried the 023 on a car with A/C, no issues.
But I haven't had a chance to try the 003 and 013 yet.
Now that I think about it, logically the 003 will not have the A/C control, the 96/97 spec ITR never came with the A/C option.
Old Apr 9, 2008 | 04:47 AM
j_scobar's Avatar
I'm running a 003 with my Type-R, and there are no issues with the A/C at all.
leftyone2
Aug 30, 2012 09:42 AM
Revi
Oct 11, 2006 03:15 PM
BignevadaBoB
Jan 15, 2005 11:42 PM
jdmEKhb
Dec 13, 2002 10:39 AM
jdmEKhb
Dec 2, 2002 08:25 AM
