1995 honda prelude si startin problems!
ok this is my first time to this but my lude is havin probles startin! when i jump start it. it start with no problem . i let it run for a while than when i turn it off(no more that 5 sec) and try to start it the car doesnt crank you just here the starter. i tested the alternator,starter, bought new positive and negative cables too. still does the same thing. can someone please tell me wuts wrong!!!
How old is the battery?
What do you mean all you hear is the starter? Do you mean all you hear is the engine being turned over or do you mean you hear the starter solenoid engage?
when the bat. is fully charge it will just turn ove a bit but the second try all you here is the stater! but when i jump started it turns on with no pro.
Is the clutch pedal fully engaging?If not it will do as u described..if not u might want to look back into that starter if the battery and alt. are good and it runs fine when jumped.
Could be the solenoid not moving enough juice
but i've never heard of any car doing that when the clutch isn't fully engaged I am new to hondas!!!
Derrick Carr
Honda CR-V & Element
Jan 24, 2018 06:30 AM
mikej94civex
Apr 28, 2010 07:49 PM
