k24 cylinder head
i work at honda and have the oppertunity to get a k24 cylinder head for free. i was thinking of building it up: valves, springs, retainers, cams, etc. will this work for my si? are the manifolds the same bolt patterns? sensors in the same place? its from an 03 accord. just wondering because its free and i could build it and keep my car on the road at the same time. thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i-VTEC_DOHC »</TD></TR><TR><TD CLASS="quote">yea it will work, but most every1 prefer the tsx head. k24a2 FTW</TD></TR></TABLE>
I thought "most everyone" preferred the tsx block, with a k20 head, because the k20 head breathes better?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2008fijibluesi »</TD></TR><TR><TD CLASS="quote">
I thought "most everyone" preferred the tsx block, with a k20 head, because the k20 head breathes better?</TD></TR></TABLE>
the tsx head is just as good as a a2 head..pretty much the same head except for the webs in the IN or EX ports is diff...someone correct me if im wrong
You fail!
Did you happen to notice he said 2003 Accord head? Which happens to be an i-VTEC-E cylinder head.
It will work, but it has a conventional cam on the exhaust side and doesnt have a high RPM cam lobe on the intake side. It has smaller port shapes. So NO, it wont work.
The K20Z3 head is the same as the K24A2 head.
SCC magazine even stated that the K20Z3 is a 2.0 version of the K24A2 with balance shafts.
You fail!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kidnkorner »</TD></TR><TR><TD CLASS="quote">
You fail!
It will work, but it has a conventional cam on the exhaust side and doesnt have a high RPM cam lobe on the intake side. It has smaller port shapes. So NO, it wont work.</TD></TR></TABLE>
True. Not worth the effort.
SCC magazine even stated that the K20Z3 is a 2.0 version of the K24A2 with balance shafts.</TD></TR></TABLE>
Not true. The k20z3 head is the RBC casting and the TSX is RBB.
http://www.sonshondaparts.com/...Irno=
Civic Si head
http://www.sonsacuraparts.com/...Irno=
TSX head.
As far as the block goes, having balance shafts makes them similar but I'm not sure what else
Civic Si block (notice the price, does that seem really cheap to anyone else?)
TSX block
You fail!
Civic Si head
TSX head.
TSX block
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IT GUY »</TD></TR><TR><TD CLASS="quote">Not true. The k20z3 head is the RBC casting and the TSX is RBB. </TD></TR></TABLE>
Are you going off part numbers alone? Those illustration pale in comparison to the article I read.
B18C5 head vs B16A2 head, same casting different part numbers. Not that many didn't know already th B18C5 cylinder head had minor bowl work done to it but many claim had a full port and polish.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IT GUY »</TD></TR><TR><TD CLASS="quote">spoke too quickly. I apologize. Same casting on the heads.
k24 block does have a taller 9.114" deck height compared to the k20 block's 8.350". </TD></TR></TABLE>
Yeah, thats why SCC said it was a 2.0 version of the K24A2.
Honda_Fanatic
18
Nov 11, 2007 09:54 AM
6SPD_EK
Nov 16, 2006 04:28 AM
