When jacked up, tire easily moves left and right
Old Feb 21, 2008 | 12:02 PM
Mendes's Avatar
Default When jacked up, tire easily moves left and right
like EASILY.. and it shakes like crazy..
LCA or CV?
gotta get this fixed now so any info is greatly appreciated
Old Feb 21, 2008 | 12:13 PM
crazyguy's Avatar
Default Re: When jacked up, tire easily moves left and right (Mendes)
whats the situation when u are driving it. any skaking..vibration, knocking ??
Old Feb 21, 2008 | 12:20 PM
Mendes's Avatar
Default Re: When jacked up, tire easily moves left and right (crazyguy)
shakes and vibrates (same thing?) like crazy... not so much knocking. im swapping the axle..
Old Feb 21, 2008 | 12:23 PM
instrument's Avatar
its supposed to turn easily.
is there movement in the hub?
if you take the wheel off, can you move the hub without moving the whole knuckle? if so your wheel bearing is probably shot.
Old Feb 21, 2008 | 12:33 PM
nub's Avatar
nub
Default Re: (instrument)
check the ball joints and tie rods also
Old Feb 21, 2008 | 01:46 PM
Mendes's Avatar
Joint is leaking grease pretty bad.. axle nut is off.. tranny is drained.. but now the castle nut is being a pain in the ***.. doesnt really matter cause i dont have the new axle but whatever ill pick it up tomorrow and let the pb do its work
CRJenkins13
Nov 7, 2007 05:18 AM
timcali69
Aug 7, 2007 08:52 AM
Slammed1993
Oct 16, 2006 08:19 PM
futurefastguy
Mar 28, 2005 06:47 PM
kmf0211
Sep 17, 2004 12:45 PM
