h23 base emanage map
I'm looking for an h23 base blue box emanage map. I've got everything setup for the tune, but I cant get the emanage to work correctly with the car. Everytime I harness in the emanage, it'll crank but wont start. I'm sure I still have some jumper and **** settings to tweak correctly. Before I go and screw something up, I'd feel a lot better if I had a base map to go back to.
Thanks
Thanks
emanage uses your stock ecu as its base map you just alter the values on emanage as add or take from what your stock ecu shows. so just go back over the jumper settings you shouldn't need to do anything to get your car to start as its a piggyback
