D16Z6 Oil Pan question
Old Feb 21, 2008 | 09:06 AM
Xathine's Avatar
Default D16Z6 Oil Pan question
Will a D16Y7 / Y8 Oil pan work for a D16Z6?
Old Feb 21, 2008 | 09:12 AM
crazyguy's Avatar
Default Re: D16Z6 Oil Pan question (Xathine)
yes.
Old Feb 21, 2008 | 09:13 AM
Probot's Avatar
Default Re: D16Z6 Oil Pan question (crazyguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy &raquo;</TD></TR><TR><TD CLASS="quote">yes. </TD></TR></TABLE>
x2
Old Feb 21, 2008 | 09:20 AM
Xathine's Avatar
Default Re: D16Z6 Oil Pan question (Probot)
Alright, reason I ask is because they have different part numbers
Old Feb 21, 2008 | 01:13 PM
blk92_d16's Avatar
I think you have to use the Y oil pick-up though...could be wrong.
Old Feb 21, 2008 | 01:18 PM
Xathine's Avatar
Default Re: (blk92_d16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blk92_d16 &raquo;</TD></TR><TR><TD CLASS="quote">I think you have to use the Y oil pick-up though...could be wrong.</TD></TR></TABLE>
Eh?
Old Feb 22, 2008 | 10:50 AM
Xathine's Avatar
Default Re: (Xathine)
Up top for answer.
Y8 oil pan on Z6 block with z6 oil pump / strainer.
Work?
Old Mar 5, 2008 | 09:30 PM
Xathine's Avatar
just had the chance to compare them side by side...
y8 is deeper then the z6
Old Mar 6, 2008 | 05:06 AM
Civic9390's Avatar
Beacause the y8 holds more oil. not much .3 of a qt more. so you'll have to use 3.8 instead of 3.5...
Old Mar 6, 2008 | 06:42 AM
afstvx's Avatar
i would also like to know as well.... so can you use the z6 oil pickup with a y7/y8 oilpan. other then the oilpan holding more is that the only difference
Old Mar 6, 2008 | 01:48 PM
Xathine's Avatar
Default Re: (afstvx)
yeah
i guess it will work if i put more oil in it
i'm probably just going to quit bein cheap and get a z6
Old Mar 6, 2008 | 06:07 PM
posemonkey's Avatar
in my exprience a y7 pan will not fit a z6 block. the studs on the oil pump are in different locations. y8 pan i dont know.
Xemu
Feb 28, 2007 07:46 PM
mike93eh2
Oct 4, 2006 07:29 PM
kyorishin
May 13, 2006 09:33 AM
JforJonathan
Apr 8, 2005 08:48 AM
ITSTOCK
Sep 30, 2003 08:29 AM
