losing coolant???
Old Feb 21, 2008 | 07:05 AM
T9U4ReBgO's Avatar
Default losing coolant???
is it normal for your car to use a little bit of coolant over a pierod of time??? My car doesn't smoke or run hot or anything doesnt leak at all and over a while I'll notice my coolant is getting low??
Old Feb 21, 2008 | 11:55 AM
T9U4ReBgO's Avatar
Default Re: losing coolant??? (T9U4ReBgO)
anyone?
Old Feb 21, 2008 | 12:00 PM
95jeremie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T9U4ReBgO &raquo;</TD></TR><TR><TD CLASS="quote">over a while I'll notice my coolant is getting low??</TD></TR></TABLE>
so how long is "a while"?
Old Feb 21, 2008 | 12:22 PM
EASY101's Avatar
* B A N N E D *
cars arent supposed to lose coolant. doesnt matter how long it takes to lose the coolant. you're losing the coolant somewhere somehow which I can gaurantee is not a good thing.
Old Feb 21, 2008 | 12:35 PM
p0gi's Avatar
Default Re: losing coolant??? (EASY101)
pressure test your coolant system and see if you can find a leak.
Old Feb 21, 2008 | 12:42 PM
EASY101's Avatar
* B A N N E D *
Default Re: losing coolant??? (p0gi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by p0gi &raquo;</TD></TR><TR><TD CLASS="quote">pressure test your coolant system and see if you can find a leak. </TD></TR></TABLE>
from my experience, pressure test arent always conclusive especially if it is a very small leak.
Old Feb 21, 2008 | 12:43 PM
b16a4's Avatar
pressure test the system
Old Feb 21, 2008 | 12:57 PM
T9U4ReBgO's Avatar
Default Re: losing coolant??? (b16a4)
ok I'll try that but the motor is really clean and I looked for a leak...I'll pressure test it this weekend
Old Feb 21, 2008 | 01:06 PM
p0gi's Avatar
I had a very small leak and couldnt find it until I pressure tested.
Old Feb 21, 2008 | 01:12 PM
95jeremie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EASY101 &raquo;</TD></TR><TR><TD CLASS="quote">cars arent supposed to lose coolant. doesnt matter how long it takes to lose the coolant. you're losing the coolant somewhere somehow which I can gaurantee is not a good thing. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T9U4ReBgO &raquo;</TD></TR><TR><TD CLASS="quote">is it normal for your car to use a little bit of coolant over a pierod of time??? My car doesn't smoke or run hot or anything doesnt leak at all and over a while I'll notice my coolant is getting low??</TD></TR></TABLE>
the point of the question was to find out the rate at which he is loosing coolant. that could help to determine what the problem might be.
if it's a 1/2 cup every 4 weeks it is way different than 1/2 cup every day.
Old Feb 21, 2008 | 01:58 PM
EASY101's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by p0gi &raquo;</TD></TR><TR><TD CLASS="quote">I had a very small leak and couldnt find it until I pressure tested. </TD></TR></TABLE>
not saying the pressure test is a bad idea...just saying I also a very small leak in my heater hose and the pressure test showed no sign of it.
Old Feb 21, 2008 | 02:02 PM
95jeremie's Avatar
well considering we don't know the rate of which he is loosing coolant we don't even know the size of the leak. not to mention any mods that have been done to the car. really leaving out some info...
Old Feb 21, 2008 | 02:57 PM
T9U4ReBgO's Avatar
Default Re: losing coolant??? (95jeremie)
well I turboed my car bout 2 months ago and it was full of coolant then and I notice bout a week ago that its was bout if I would guess a 1/2 to 3/4 cup low....it is a b20 turbo with a half quart radiator...
Old Feb 21, 2008 | 03:10 PM
b16a4's Avatar
btw, your not alone with loosing coolant!
Old Feb 21, 2008 | 03:26 PM
95jeremie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T9U4ReBgO &raquo;</TD></TR><TR><TD CLASS="quote">well I turboed my car bout 2 months ago and it was full of coolant then and I notice bout a week ago that its was bout if I would guess a 1/2 to 3/4 cup low....it is a b20 turbo with a half quart radiator...</TD></TR></TABLE>
getting there... what type of #'s
did you do anything to the motor? of is it stock?
Old Feb 21, 2008 | 05:49 PM
T9U4ReBgO's Avatar
nope bone stock motor with bout 40000 on it...and its on 8lbs with a base map...I just DD it right now until I get tuned in a week or two....I have gotten on of maybe a handful of times and I also have a wideband o2...
Old Feb 21, 2008 | 05:56 PM
Lewy. Dee Ayy's Avatar
maybe your head is lifting under boost? stock headstuds?
Old Feb 21, 2008 | 06:13 PM
WalkerGSR1's Avatar
Its also normal for turbo cars to burn off a little coolant here and there. Just check your oil and coolant levels everyday especially if you have been beating on the car.
Old Feb 22, 2008 | 03:12 AM
T9U4ReBgO's Avatar
Default Re: (WalkerGSR1)
well if my head was lifting would the be coolant everywhere???
Old Feb 22, 2008 | 03:18 AM
Default Re: (T9U4ReBgO)
it does not lift THAT much but it will lift enough to where coolant can leak past the gasket.
also maybe you just have a blown headgasket.
Old Feb 22, 2008 | 04:44 AM
T9U4ReBgO's Avatar
Default Re: (Lewy. Dee Ayy)
It doesnt smoke or run bad...and I just did a compression test wouldn't it effect that if the headgasket was blown?
Old Feb 22, 2008 | 05:12 AM
WalkerGSR1's Avatar
When my headgasket was blown earlier, it didn't burn anything had perfect compression and ran fine until i boosted it. It would fill the resevoir tank and spray all over my engine bay.
Old Feb 22, 2008 | 06:19 AM
HMTforlife's Avatar
Let me guess, SOHC?
Old Feb 22, 2008 | 10:22 AM
T9U4ReBgO's Avatar
Default Re: (HMTforlife)
no my car is a b20
Old Feb 22, 2008 | 03:54 PM
95jeremie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T9U4ReBgO &raquo;</TD></TR><TR><TD CLASS="quote">nope bone stock motor with bout 40000 on it...and its on 8lbs with a base map...I just DD it right now until I get tuned in a week or two....I have gotten on of maybe a handful of times and I also have a wideband o2...</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lewy. Dee Ayy &raquo;</TD></TR><TR><TD CLASS="quote">maybe your head is lifting under boost? stock headstuds?</TD></TR></TABLE>
that's what i was thinking
i wouldn't stress it till after your tune
if your running on a base map your timing and well everything is a little off
that might be what's causing you to have the slite coolant leek
if you were sohc i would say head studs are a must but your dohc and well i just don't know much about that lol
from my understanding you should be ok with the stock head bolts on 8psi
so what i would do is drive the car like a grandma until you get it tuned.
try your best to stay out of boost and see if it helps.
if so you know what your problem is
