timing belt issue
Old Feb 21, 2008 | 03:20 AM
ef-hatchcrap's Avatar
Default timing belt issue
I have searched but got mixed answer I have a d15b2 block with a z6 head I need to know what timing belt to use.
I am using a z6 belt now and it is to big there is to much slack.
Old Feb 21, 2008 | 04:35 AM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
d-series.org will help you much more then we can.
Old Feb 21, 2008 | 12:35 PM
Default Re: (ComeOnKip)
bump
Old Feb 21, 2008 | 04:07 PM
de1991hatch's Avatar
Default Re: (ef-hatchcrap)
i have a similar swap and used the z6 belt, did you also get a new belt tensioner?
Old Feb 21, 2008 | 04:35 PM
nihad's Avatar
Default Re: timing belt issue (ef-hatchcrap)
well the vx and the d15b2 are bigger then the z6 belt the a6 is the longest one so the z6 will be the belt u will use have u pushed out the tensioner all the way it will go i have a d16a6 with a z6 head and it was weird at first but it actually works i use the oem tensioner for the a6 and my tensioner is all the way on one side.
Snafubmx234
May 9, 2008 07:25 PM
ef-hatchcrap
Apr 18, 2008 03:43 PM
StupidSlowRSX
Feb 15, 2008 03:00 AM
bigwill_2004
May 28, 2007 08:24 PM
ViperRedCRX
Apr 24, 2003 12:41 PM
