which axles to use
Old Feb 21, 2008 | 01:01 AM
efmike84's Avatar
Default which axles to use
i have a ef hatch, i am putting a lsv in but i am not sure what axles to use. if anyone can please help should i just use 90-93 integra axles? please help!!!![IMG][/IMG]
Old Feb 21, 2008 | 01:49 AM
helpmycivic's Avatar
Default Re: which axles to use (efmike84)
you can use the 90-93 axles if your running the 90-93 halfshaft. with my setup i had a complete 94 integra as a donor car so i used the dc axles and halfshaft and worked fine. the only problem if you use the dc stuff is you will have to replace the driver side tranny output shaft (axle) seal as it has a smaller diamiter then the da halfshaft and if not replaced you will just dump trans fluid as fast as you can pour it in...lol i found this out the hard way! just my .02 good luck
Old Feb 21, 2008 | 04:08 AM
CRX Toad's Avatar
HOLY MOLY SEARCH OR LOOK IN THE FAQ I HAVE SEEN THIS AXLE THREAD 3 TIMES ALREADY THIS MORNING.
mr-mister
Sep 3, 2005 10:05 AM
b16crx0062004
Nov 17, 2004 06:13 PM
foursquarepunk04
Feb 3, 2004 08:42 PM
Eggman
Feb 8, 2002 10:45 AM
JJ-Built
Jan 2, 2002 08:27 AM
