Took off dash, Re-installed and now HEATER DOESN'T WORK!? HELP!
Hello Honda-Tech once again... I have another problem with my baby ( 88 CRX ) and i need your help/opinion!
I took off my dash in order to install my pedal assembly.... I know I know i didn't have to take off the dash to do it, But it made it just that much easier. Anyways after installing my dash i turned on my heater and it blows air, It just doesn't blow hot or even warm? What may the problem be?? Thanks again Honda-Tech....
check the 2 wires that opens the heater valve, are they connected to the climate control? when you rotate the cold/hot ****, the wires open/close the heater valve allowing the hot water to circulate.
Which wires would it be?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crexer »</TD></TR><TR><TD CLASS="quote">check the plugs down under the glovebox maybe you forgot to plug something up!</TD></TR></TABLE>
maybe ones hanging loose? Did those 2 cables get hooked back up to the climate control, that when the **** is turned it pulls or retracts the cables opening the heater valve on the firewall? Have a buddy turn the **** and you look at the firewall under the hood and see if that valve is opening
dohc-father
Jan 21, 2009 08:47 AM
