a little 1000hp aw action
Old Feb 20, 2008 | 06:29 PM
manifoldmiketyson's Avatar
Default a little 1000hp aw action
i'm making this for my friend. thinks he can make 1000whp on his mr2. we'll see.....
i'm going to try to have it done this weekend, but most likely next week.
Old Feb 20, 2008 | 07:30 PM
ebydrc's Avatar
Banned
i like the table minus the clutter
Old Feb 21, 2008 | 05:23 AM
GenIIIMrDuece's Avatar
Default Re: (ebydrc)
looks good!
It should fit a little better than the last one..
Old Feb 21, 2008 | 05:26 AM
weiRtech's Avatar
OG Fabricator
that must be a bitch to work on... nice work.
Old Feb 21, 2008 | 05:31 AM
140sx's Avatar
no trunk mount
Old Feb 21, 2008 | 06:01 AM
Turbo-charged's Avatar
Default Re: (weiRtech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weiRtech &raquo;</TD></TR><TR><TD CLASS="quote">that must be a bitch to work on... nice work.</TD></TR></TABLE>
i had a mr2 when i was 17, i sold it for that reason! every mr2 ive worked on since then has been a nightmare too. they put the oil filter 1mm away from the turbo, so even oil changes are a pain in the *** b/c the filter always is seized lol
Old Feb 21, 2008 | 06:17 AM
Default Re: (Turbo-charged)
my oil filter is on the bottom of the motor ya should have done a gen3 swap and you wouldnt have had that problem
..no not really anymore.. moroso pan now.. oil filter in the gen1/2 spot
Old Feb 21, 2008 | 01:18 PM
mrbsponge's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebydrc &raquo;</TD></TR><TR><TD CLASS="quote">i like the table minus the clutter</TD></TR></TABLE>
i dont think he works much on that table my friend, probably just used it to snap some pics
cmon now dont act like we all dont have atleast ONE table of slutter in the shop somewhere
Old Feb 21, 2008 | 05:18 PM
Default Re: (mrbsponge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge &raquo;</TD></TR><TR><TD CLASS="quote">
cmon now dont act like we all dont have atleast ONE table of slutter in the shop somewhere </TD></TR></TABLE>
lol, i do most of my work afterhours. i've been pencil pushing more then anything lately. not having a lot of drive to clean up my bench after working 12 hours.
so the water tanks are pretty much done and i welded the pipe for the inlet. the inlet tank and both water tanks are welded to the core as of tonight. i probably won't get a chance to work on it until monday, but we'll see. i'll snap some pics tomarrow.
the old setup was pretty good too. big though. on a 95 degree day tuning for about 2 hours and runing tap water through the core produced a maximum of 60 degree intake temps. the car was only runing 10psi at the time, but it still held up pretty well to heat soak.
i'm hoping we can get some similar intake temps without all the weight and size.
the old core was an air to air core and this one is air to water, so i'm hoping it will work better.
Old Feb 23, 2008 | 01:55 PM
Default Re: a little 1000hp aw action (manifoldmiketyson)
i used pulse on the tank to core welds. thats 190amps with a background of i think 40~50amps at .08 pulse frequency. i was using 3/32 4043 rod.
tank welds are 1/16 4043 with peak current at 110 amps. material is .090 6061 t6.
Old Feb 23, 2008 | 02:44 PM
AssItch1's Avatar
nice work... is that the garrett core?
Old Feb 23, 2008 | 02:55 PM
Schister66's Avatar
Man U FTW
Is that Air-Water Intercooler going to be large enough to support near 1000whp??
Old Feb 23, 2008 | 04:39 PM
Default Re: (Schister66)
well find out
Old Feb 24, 2008 | 09:30 AM
JDMCRX's Avatar
Default Re: (GenIIIMrDuece)
Very nice. ANy pics of the car and more of the set up ?
Old Feb 24, 2008 | 11:39 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">Is that Air-Water Intercooler going to be large enough to support near 1000whp??</TD></TR></TABLE>
yep. thats a garrett core rated at 1000hp for a/w purposes. its the same core that precsion uses for their a/w units.
a/r is a ton more efficent about sheading heat, so the size doesn't really matter. problem is trying to combat heat soak once the water is heated. for a drag car its fine, but daily driving can be more of a challenge.
Old Feb 24, 2008 | 11:51 AM
AssItch1's Avatar
Default Re: (manifoldmiketyson)
i'm going for somewhat the same setup...
i'll be counting on a big heat exchanger... it's a bit bigger then my normal radiator... and i'll constantly have a fan blowing at it...
i think that'll be enough to counter the heatsoak...
Old Feb 24, 2008 | 12:06 PM
Default Re: (AssItch1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AssItch1 &raquo;</TD></TR><TR><TD CLASS="quote">i'm going for somewhat the same setup...
i think that'll be enough to counter the heatsoak... </TD></TR></TABLE>
thats usually were people screw the system up. they put a oil cooler or somthing super dinky on it and expect it to work. so as intake temps rise, they start saying a/w is bad for daily driving.
fittings play a big roll. make sure that the fittings chosen are restrictive in bends.
at my old shop a s/c nsx came it with 180 degree charge temps. he was running straight coolant and some wierd fitting on the pump.
we swapped them out for better fitting and switched to water and water wetter and it dropped intake temps i think 40 degrees @ wot. he also wasn't running a very large tank on the system, so there wasn't that much capacity in the first place.
Old Feb 24, 2008 | 12:37 PM
AssItch1's Avatar
i'll be keeping an eye on this project...
Old Feb 24, 2008 | 02:03 PM
Schister66's Avatar
Man U FTW
I have a couple of questions...
1. What does a unit like that cost after the reservoir and core, etc?
2. On a smaller setup, would an A/W be efficient enough for a DD 450whp setup??
Old Feb 25, 2008 | 06:10 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">I have a couple of questions...
2. On a smaller setup, would an A/W be efficient enough for a DD 450whp setup??</TD></TR></TABLE>
i can't give my cost, but they retail for around $350 for the core.
cost of a good a/w setup is around $1k usually.
yeah, its way more efficent then an a/a setup, however heat soak is tough to combat.
Old Feb 25, 2008 | 09:46 AM
92LSVTEC's Avatar
damn nice peice!
welds are looking good mikey
Old Feb 26, 2008 | 12:55 PM
5thgenallmotor's Avatar
Only one comment on this one mikey! When you test for leaks use a air regulator and cover your nuts!
Looks good. I will call you tonight, been busy!
Old Feb 26, 2008 | 05:07 PM
Default Re: (5thgenallmotor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5thgenallmotor &raquo;</TD></TR><TR><TD CLASS="quote">Only one comment on this one mikey! When you test for leaks use a air regulator and cover your nuts!
Looks good. I will call you tonight, been busy! </TD></TR></TABLE>
i probably won't test it with 150psi this time, but i'm still covering my nuts. i've been lazy the last couple nights, so no progress.
Old Mar 3, 2008 | 06:19 PM
so i finally got some time to work on the intercooler again. the exit for the intercooler has to come off one side of the core and there isn't a lot of space there, so i decided to go a different route then just a box.
i used half of a 3" .120 wall tube and some flat sheet. the sides of the tank are actaully at different angles, so i had to twist the plate to fit.
Old Mar 3, 2008 | 07:42 PM
mrbsponge's Avatar
holy crap mikey.
how much time you have in this project. i am doing something similar with an MX6/probe gt air to air, i boxed it in to make an A2W intercooler. just somethin i felt like messin with sincei had all the cap layin around.
