Need info on H22 block with liners and Higher compression. . .
Old Feb 20, 2008 | 04:55 PM
2fastGSR's Avatar
King of the One Liners
Default Need info on H22 block with liners and Higher compression. . .
So i picked up an h22 block with 89mm Darton Liners in it. I know this is not the greatest option compared to sleeving but the price of the shortblock was great. Does anyone have any input on running these liners with 13.5 - 14 :1 compression?
Thanks guys
Old Feb 28, 2008 | 04:41 AM
CRAZY-EG9's Avatar
Default Re: Need info on H22 block with liners and Higher compression. . . (2fastGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2fastGSR &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks guys</TD></TR></TABLE>
bump...
Old Feb 28, 2008 | 08:40 PM
95dcsleeper's Avatar
Default Re: Need info on H22 block with liners and Higher compression. . . (CRAZY-EG9)
so it is already sleeved? ...... your at the blocks limit you'll have alot of power when finished
Old Feb 29, 2008 | 07:18 AM
2fastGSR's Avatar
Default Re: Need info on H22 block with liners and Higher compression. . . (95dcsleeper)
you can take an h block to 90.5- 91. No its not sleeved it has liners in it, they are different then sleeves- which is why i asked this question . .
Old Feb 29, 2008 | 08:43 AM
hybrid2007's Avatar
They are still sleeves man, just a different design.
At 89mm you are at the limits of them. MID's may be able to go more though
Old Feb 29, 2008 | 08:59 AM
2fastGSR's Avatar
Default Re: Need info on H22 block with liners and Higher compression. . . (hybrid2007)
I am not about to start going back and forth about the difference between a "liner" or a sleeve.
I never asked about boring the liner out any bigger, as they are not sleeves they are about as strong as a stock block, I know this. I was just asking about experiences with them, thats all
Old Feb 29, 2008 | 03:09 PM
hybrid2007's Avatar
No wories man, just stating what i think is rght. I have the same liners/sleeves in my block bored to 88mm.
My take on it is that max bore if your boosting is 88 and 89 for N/A apps when dartons iron liners are being used.
Old Feb 29, 2008 | 03:59 PM
Chris Tune's Avatar
I never asked about boring the liner out any bigger, as they are not sleeves they are about as strong as a stock block, I know this. I was just asking about experiences with them, thats all </TD></TR></TABLE>
my friend you are LOST... strong as a stock block... yeah right...
FYI liners = sleeves... its just not the MID design...
and i have used stock replacement liners/sleeves to a lot of HP, so you should have no problem there
Old Feb 29, 2008 | 04:23 PM
2fastGSR's Avatar
Default Re: Need info on H22 block with liners and Higher compression. . . (Chris Tune)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris Tune &raquo;</TD></TR><TR><TD CLASS="quote">
and i have used stock replacement liners/sleeves to a lot of HP, so you should have no problem there </TD></TR></TABLE>
This thread is turning into exactly what i did not want it to and what honda-tech is so famous for. People imposing their "knowledge" everywhere.
The LINERS that are in this block are simply iron liners. They are not a "sleeve" as one would think. The words- only a little stronger than a stock sleeve as the majority of the stock sleeve is left, these just line it- are in an email response from darton that i received. They just allow you to run forged pistons in the frm H block. THE END. they are not sleeves in any sense of the word.
Please dont proceed to tell me what I have, when i know full well what it is.
I asked for experiece with these and you gave it to me in the last sentence, so thanks
Old Feb 29, 2008 | 05:42 PM
Chris Tune's Avatar
i've run close to 600 on stock "replacement" liners... and i have seen and kinda installed darton replacements... WAYYY stronger than regulars and i bored one to 90mm lol... if that aint a sleeve tell the darton representative to kill himself
Old Mar 1, 2008 | 06:11 AM
hybrid2007's Avatar
Default Re: (Chris Tune)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris Tune &raquo;</TD></TR><TR><TD CLASS="quote"> if that aint a sleeve tell the darton representative to kill himself </TD></TR></TABLE>
Old Mar 1, 2008 | 08:55 AM
2fastGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris Tune &raquo;</TD></TR><TR><TD CLASS="quote">if that aint a sleeve tell the darton representative to kill himself </TD></TR></TABLE>
hahaha thats freakin great.
thanks for the insight guys
Old Mar 1, 2008 | 09:50 AM
98vtec's Avatar
moderator emeritus
jake,
i believe we have spoken about this, but i am running these liners in the h23vtec. 12.2:1 compression. I can't really give any comments about them since the engine is not running but i have no reason at this point to doubt them.
Old Mar 1, 2008 | 10:53 AM
95 integra's Avatar
Wow....what a cluster expletive over the meaning of words. Honda uses what most people consider a half and half "sleeve". Basically half the "sleeve" is aluminum and cast with the block and the other half is a steel "liner" that is pressed in. Apparently some people think the "sleeve" is the aluminum part and the "liner" is the steel part. Darton makes the distinction between the two so that you dont buy their replacement sleeves (ie liners....the name that Darton calls them) thinking they are a high performance sleeve.
In the commonly used honda jargon, you have replacement sleeves and performance sleeves....both are known as sleeves to 98% of the market. Even darton sells M.I.D. sleeves, flanged sleeves, repair sleeves, etc....and they refer to them all under a blanket term called a "liner"...not to mention if you look at the Darton catalog, they only sell sleeves....no liners.
As far as Im concerned, you are all morons because a sleeve is something I wear when it is cold outside and a liner is something I put in a trash can so I can easily remove it and move it to the dumpster......
Old Mar 2, 2008 | 11:52 AM
Chris Tune's Avatar
Default Re: Need info on H22 block with liners and Higher compression. . . (95 integra)
so true... so true...
ill put a few sleeves over my engine so it keeps it warm and cozy
michaelprice83
Feb 1, 2009 07:27 AM
rollercosta123
Aug 30, 2006 07:28 PM
adam94lude
Oct 19, 2005 01:35 AM
acr91
Apr 6, 2004 05:20 PM
kwik93si
Apr 2, 2003 02:16 PM
