can EOM retainers be used with dual valve springs and crower 402 cam?
Old Feb 20, 2008 | 03:05 PM
Snail Tuning's Avatar
Default can EOM retainers be used with dual valve springs and crower 402 cam?
just wandering if you must upgrade from stock retainers to titanium if you run the crower 402 turbo cams, dual valve springs, and redline at say 8k.
1995 B18B engine.
T3/T4E 58 .48trim turbo
sp prototype 1 manifold
eagle rods
aris 9.1:1 comp
crower or ferrea springs (trying to keep initial cost down but want springs in now cause its easy to do with the head off.)
Goal is 350hp daily and when we want more ill add
crower 402 cams, blox intake manifold, larger TB
May get Golden Eagle sleeves, not sure if funds will permit at this time.
Thanks for the help.
Old Feb 20, 2008 | 03:15 PM
KillAHonDa's Avatar
spend a little more and upgrade to the titanium retainers.
Old Feb 20, 2008 | 03:48 PM
ctr83's Avatar
Default Re: (KillAHonDa)
do you mean oem, on but you should get retainers. and what cams do you have now?
Old Feb 20, 2008 | 05:37 PM
Default Re: (ctr83)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ctr83 &raquo;</TD></TR><TR><TD CLASS="quote">do you mean oem, on but you should get retainers. and what cams do you have now?</TD></TR></TABLE>
Yes sorry for the typo.
Cams are stock. For now. just trying to spread out the cost of the build rather than having a huge bill upfront.
Old Feb 21, 2008 | 11:46 AM
ctr83's Avatar
Default Re: (Snail Tuning)
gsr,itr,ctr are some good cams for turbo honda. i wouldn't even spend the $$$ on turbo cams.
.........but thats just my .02 on that.
Old Feb 21, 2008 | 12:01 PM
Default Re: (ctr83)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ctr83 &raquo;</TD></TR><TR><TD CLASS="quote">gsr,itr,ctr are some good cams for turbo honda. i wouldn't even spend the $$$ on turbo cams.
.........but thats just my .02 on that.</TD></TR></TABLE>
When your boosted turbo cams help more than an agressive n/a cam. plus im non-vtec. can't use GSR, ITR, or CTR cams.
Old Feb 21, 2008 | 12:09 PM
quicksilver1689's Avatar
i ♥ snails
get some 403's and cam gears to figure out how much or little overlap your motor wants
Old Feb 21, 2008 | 12:24 PM
ExVtec's Avatar
Default Re: can EOM retainers be used with dual valve springs and crower 402 cam? (Snail Tuning)
I am running Crower Valve springs on my b16 head w/OEM retainers and gsr sticks. 9k.
For what it's worth, imo, if you are using a cam with a low profile, I believe you can get away with it if you aren't reving to the moon.
If you start bumping up to a higher ramp, you are putting more strain on the compenents, I'd certainly upgrade.
Again, just my opinion.
PhatBoy5015
Aug 23, 2006 09:46 PM
jaydm7182
Nov 2, 2005 05:48 PM
allmotorh23
Mar 3, 2005 10:12 PM
TurBoTeG
Aug 9, 2004 11:58 AM
sutrusu
May 31, 2002 04:46 AM
