Looking 4 Opinions: Budget GS-R Rebuild
Old Feb 20, 2008 | 10:56 AM
BigPlansNoMoney's Avatar
Default Looking 4 Opinions: Budget GS-R Rebuild
219,XXX on the ticker on my 95 GS-R Sedan. I want to slowly start collecting new and used parts so I can tear it down and build it back-up once it hits 250K.
Trying to keep it cheap. Give me some ideas. Thanks in advance.
Old Feb 20, 2008 | 11:13 AM
denraweb's Avatar
Default Re: Looking 4 Opinions: Budget GS-R Rebuild (Justin_Bradley)
Only thing I can say is Ebay. Find people there and LOCALLY that were going to do a rebuild/build, but then had their car stolen or wrecked to a point where they couldn't use the parts...that's how I got my stuff. Most of the stuff I bought for my build were still in original packaging. Good Luck!
Old Feb 20, 2008 | 01:07 PM
grtek's Avatar
rs pistons itr/b16 spec, way cheaper than forged and makes great power if you wanna go the n/a route. Those run around $150~ with pistons rings
But first what are your plans for your engine/car? DD with some decent n/a power? 200whp+ housin? Boost fiend?
Old Feb 20, 2008 | 01:54 PM
Default Re: Looking 4 Opinions: Budget GS-R Rebuild (grtek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grtek &raquo;</TD></TR><TR><TD CLASS="quote">rs pistons itr/b16 spec, way cheaper than forged and makes great power if you wanna go the n/a route. Those run around $150~ with pistons rings
But first what are your plans for your engine/car? DD with some decent n/a power? 200whp+ housin? Boost fiend?</TD></TR></TABLE>
The part in bold pretty much sums it up. I may add a small shot of nitrous (nothing more than 50HP), but it's not set in stone yet.
So are you saying get a set of new or used pistons from a B18C5 or a B16A? Do you know the casting number? What would make these better than just replacing the stock B18C1 castings?
Old Feb 20, 2008 | 02:12 PM
grtek's Avatar
http://www.hondamarketplace.com/zerothread/1569878
Those are the ones I'm talking about. The ITR/B16 pistons have higher domes so they yield a higher compression. And since they're an oem design your not really sacrificing quality as long as it's built and tuned right.
Throw in some ITR/CTR cams, make sure you get bigger bolts for your rods and make sure the whole rotating assembly is balanced. That will give you a nice a power bump internally. Then you can had i/h/e to get some extra power.
cmerce
24
May 23, 2010 10:53 AM
DARKTEG_
Sep 20, 2006 10:35 AM
1meanteg
Feb 22, 2006 05:42 AM
hondaeg8
19
Jun 6, 2005 09:30 AM
xplanetearth420x
May 26, 2004 10:16 PM
