problems need help
Old Feb 20, 2008 | 09:28 AM
wompmaster's Avatar
Default problems need help
im haveing problems with my 97 civic .the car was running great it has a 2000 single vtec with a d15 trans wich i like better cause the gears r longer. any way im spraying with a nitrous express kit and it was running good with a 100 shot but recently its been acting up on me. when i drive it normally it drives find but when i shift the gears hard or fast it looses power like if it wants to shut of .what can this be? by any chance if the axel comes out will th car shut of i need help quickly please.
Old Feb 20, 2008 | 10:09 AM
A lil 2.3l action's Avatar
Default Re: problems need help (wompmaster)
is the motor built at all or is it completely stock...
how often do you spray the motor...
Old Feb 20, 2008 | 10:38 AM
wompmaster's Avatar
Default Re: problems need help (A lil 2.3l action)
its completly stock and i spray probably 3 to 5 times a day
Old Feb 20, 2008 | 10:44 AM
coneheadsracing's Avatar
so is it only loosing power when you spray, or both.
Old Feb 20, 2008 | 10:57 AM
Default Re: problems need help (coneheadsracing)
3-5 of 100 shots on a stock motor is deff not that healthy your fixin to mess ur motor up quickly
Old Feb 20, 2008 | 11:23 AM
wompmaster's Avatar
both it only happens when i shift it hard or when i do a burn out it dies out the batt. light cuts on and then off and th e check engine light also.if drive normall and shift normal its fine but when i shift hard and make the engine shake it looses power
Old Feb 20, 2008 | 11:32 AM
battery secured properly? How about the engine, all mounts are good to go. Seems like you are rattling something loose.
Old Feb 20, 2008 | 12:14 PM
wompmaster's Avatar
yeah thats what i was thinking
Bored&Stroked
Jul 18, 2013 02:11 AM
Crumley
21
Dec 10, 2009 08:58 PM
Honda_hatch 96
Jul 15, 2004 06:49 AM
GirlyGirlGSR
Oct 31, 2003 07:58 AM
