HF Bender
Old Feb 20, 2008 | 07:13 AM
Running925's Avatar
Default HF Bender
hey guys, i just need a some small pipes bent for a light bar that i'm going to make for my yamaha rhino & i'm concidering buying the cheapo HF bender for some small tasks & little projects that i've got going on around the garage.
Just curious if anyone has used something like this & if it worked for them or not.
Old Feb 20, 2008 | 08:36 AM
k24em2's Avatar
Default Re: HF Bender (Running925)
Those benders kink the tubing pretty badly
Old Feb 20, 2008 | 09:35 AM
96supercharged's Avatar
Default Re: HF Bender (k24em2)
I've seen a video online, where if you pack the tubing with sand really tight, then you can use one of those benders and not have it kink too much.
I built my bender for $400.00 with die, and it's powered by the push of a button. It's worth it if you end up doing enough projects.
Old Feb 20, 2008 | 10:21 AM
Running925's Avatar
Default Re: HF Bender (96supercharged)
yea, i've got the link to the instructions that you used somewhere.
maybe i should go that route, i've got a drill press already that i can drill the holes with, i seem to rembmer you saying that was the most diffacult part or what not.
JDubya
Welding / Fabrication
14
Jun 5, 2008 08:21 AM
MattP
Apr 16, 2006 09:39 PM
MaddMatt
38
Feb 26, 2005 08:15 AM
