In to the Allmotor scene..! "again" Project b18c build with pictures
Old Feb 20, 2008 | 04:47 AM
atec's Avatar
Default In to the Allmotor scene..! "again" Project b18c build with pictures
Lets see.
Basic info.
-block b18c6 stock 3point girdle
-p73 Crank
-Eagle rods
-Balanced to 0,1g tolerances
-Wiseco pistons (13,2:1)w/stock combustion chamber.
-I will mill down the head estimated 0,060", but I`ll have to meashure when I get the pistons on how much squish and P2V clearence I got.
-Custom spec cams @ 0.050" lift .500" and 263dur intake .500, 272dur exh.
-2layer gasket(we also have to meashure clearences before choosing 2-3layer.
-TWM itb
-ACL bearings
-B16 head
-P72 LMA
-Moroso pan
-Omni valvtrain Flatface valves
EMS
Hondata s300 running off Alpha-N TPS signal.
Tri Y header
2,5" custom exhaust
I also want to thank Scott at king motorsports for the nice service they provide..!!
I`ll post pics of the engine (empty of internals first so you get an idea of what it looks like)
Modified by atec at 6:04 AM 2/20/2008
Modified by atec at 4:31 PM 2/20/2008
Modified by atec at 4:36 PM 2/20/2008
Modified by atec at 4:59 PM 2/20/2008
Old Feb 20, 2008 | 04:51 AM
B18C-R(EG)'s Avatar
Default Re: In to the Allmotor scene..! "again" Project b18c build with pictures (atec)
lookin good!
what are your goals?
Old Feb 20, 2008 | 04:55 AM
atec's Avatar
Default Re: In to the Allmotor scene..! "again" Project b18c build with pictures (B18C-R(EG))
Around 230whp are estimated.
My goal are to get as much average hp as possible rather than peak power on this one.
Old Feb 20, 2008 | 05:01 AM
atec's Avatar
Lets see, some pics in to the depth.
Still waiting for pistons and valves. OMG I hate to wait..
Old Feb 20, 2008 | 05:03 AM
polishedturd's Avatar
I like PIE
nice, what chassis?
atec's Avatar
Head waiting for valves. and milling. as said above, if the valvepockets P2V clearences and the squish P2H clearences allow I will mill down about 0.060" to accieve the compression ratio that we want.
The engine is beeing built for E85
I use a contricity gauge to meashure the valveseat runout to make shure the seats are concentric after all angles/radiuses are aplied if not the seats must be replaced.
Also note the unfinished area around the valveguide, some parts of the port beside this spot, must never be removed, also some other areas
As for this the Combustionchamber is Worked out a bit to help maintain mixture homogeneity, flow, and combustion travel as well as increasing flow at high lifts by descruding valves, even though the almost stock bore is limiting the amount beeing taken.
It may look very shiny (polished) but the finish is nowere near polished.
280grit is beeing used to smooth it.
The Intake channel is smoothed with a 120grit emery paper and the exhaust runner are smoothed with 280grit emery.
Also the divider are rounded(at a point in the port work it got knife edged and I dont want that)
here is a funny calculation just to see how fast the intake valve opens per second when engine have about 10000 rev pr minute.
here it goes.
<U>10000</U>/60 =83,34 O pr second
That clears up why you want a rough finish on you intake runners.
The engines are based of a non-direct (I dont know the english word) Injection leaving the atomized fuel on the intake walls and on the back of the valve.
most of it ends up on the walls and around the valve area, until the valve finally opens and draws in the air fuel mixture. Keeping the walls rough helps break up the fuel particles before entering the swirl chamber.
The better you can mix the charge with air the more efficient you can use energy suplied.
Modified by atec at 10:15 AM 2/25/2008
Old Feb 20, 2008 | 06:19 AM
98vtec's Avatar
moderator emeritus
Default Re: (atec)
instead of just posting pictures, maybe you could explain the process that you are going through and what these pictures are supposed to represent.
cool build and all, but no one is really learning anything and after all, that is what this forum is for.
Old Feb 20, 2008 | 03:33 PM
atec's Avatar
Default Re: (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">instead of just posting pictures, maybe you could explain the process that you are going through and what these pictures are supposed to represent.
cool build and all, but no one is really learning anything and after all, that is what this forum is for.</TD></TR></TABLE>
I have edited with some details.
Modified by atec at 6:44 AM 2/21/2008
Old Feb 21, 2008 | 05:33 AM
atec's Avatar
Default Re: (polishedturd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by polishedturd &raquo;</TD></TR><TR><TD CLASS="quote">nice, what chassis?</TD></TR></TABLE>
It is a EK chassie.
I will post up pictures of it. just need to go through 2000pics first..
Old Feb 21, 2008 | 06:15 AM
atec's Avatar
Found them.
Here is the car that the engine is going in to.
It did 223.7 whp at 14,7psi on a stock 1,5 vtec(d15z6)
Now I found it was time to build it a little diffrent before we sell it.
Dash
Old Feb 21, 2008 | 09:25 AM
jphil101's Avatar
Default Re: (atec)
that is a damn clean car....props keep us updated on when u get the motor in it and get it runnin
Old Feb 21, 2008 | 09:51 AM
Godspeed07's Avatar
Default Re: (jphil101)
sorry for the ignorant question but i don't have much experience with itbs.........that black thing around the "trumpets" does what exactly??? is there a filter that goes on top of that??? or like a resonator box or something??? What is it? Thanks in advance.
Old Feb 21, 2008 | 12:18 PM
atec's Avatar
Default Re: (Godspeed07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jphil101 &raquo;</TD></TR><TR><TD CLASS="quote">that is a damn clean car....props keep us updated on when u get the motor in it and get it runnin </TD></TR></TABLE>
Thanks man glad to hear you liked it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Godspeed07 &raquo;</TD></TR><TR><TD CLASS="quote">sorry for the ignorant question but i don't have much experience with itbs.........that black thing around the "trumpets" does what exactly??? is there a filter that goes on top of that??? or like a resonator box or something??? What is it? Thanks in advance.</TD></TR></TABLE>
Hi, It is the underside of a carbon plenum
Modified by atec at 1:28 PM 2/21/2008
Old Feb 21, 2008 | 12:19 PM
9t4fodo's Avatar
Nice looking buildup...super clean, looks like it'll run nice and strong!
Old Feb 21, 2008 | 12:31 PM
200TS EC's Avatar
Very Nice!!!
Old Feb 21, 2008 | 03:23 PM
atec's Avatar
Default Re: (200TS EC)
Thanks
Old Feb 21, 2008 | 03:45 PM
atec's Avatar
You probably drown in pictures haha.
here is some more.
Old Feb 21, 2008 | 06:18 PM
MR.POWERSHIFT's Avatar
nice build, very clean throughout
Old Feb 21, 2008 | 06:46 PM
American.Graffiti's Avatar
Default Re: (MR.POWERSHIFT)
Old Feb 21, 2008 | 09:59 PM
Combustion Contraption's Avatar
Swirl
Knife-edgine
Good job on the concentricity gauge.
Old Feb 23, 2008 | 02:12 PM
atec's Avatar
Default Re: (Combustion Contraption)
Hey thanks.
Old Feb 26, 2008 | 11:58 AM
atec's Avatar
Last pics before the parts are here.
I`ll have some more pics up.
this time Im meashuring the chamber volume, after this I will be meashuring the cyl/piston volume to know the total volume and C/R
The meashuring will be done again with the new valves in later to get the exact volume. syl 4 had 2cc less than the three other sylinders so I had to even that out.
Here is some pictures:
Old Apr 3, 2008 | 07:16 PM
atec's Avatar
I picked up some parts at the local postoffice today..
only waiting for some lightweight rods now so I can start to assembe, the eagles were sold to someone that needed it more than me..
pics:
You allready know the details.
Old Apr 4, 2008 | 05:10 AM
silver-16v's Avatar
Default Re: (atec)
lookin good
Old Apr 4, 2008 | 05:23 AM
Coming along nicely.
