#1261 is running again -WOT! (well not quite yet)
Old Feb 19, 2008 | 11:52 PM
dsav4shawn's Avatar
Default #1261 is running again -WOT! (well not quite yet)
Finally fired it off around 130 am... bit loud with just a downpipe. Pretty excited for the fact it's been on jackstands since May. More to come and pictures from along the way.
Question is: Tuning? Was (IS) tuned w/ s200b at 5lbs jrsc. The only changes that I've made are: upgraded pulley to 8lb and changed header from 4-2-1 comptech to a kamikazi 4-1. I'm having a hard time tracking down a decently priced and competent hondata tuner. Several people have advised me to change to chrome? What are thoughts on tuning and if I should change from hondata. Would it be crazy to drive it with it tuned at 5lbs just for a break in period (500ish miles)?
Run down of what I've done (new):
Crank, bearings, head bolts, rings, valve stem seals, timing belt, plugs, all (every freaking one) seals top and bottom, water pump, 6 puck act clutch and hd pressure plate, t/o bearing, injector o rings, header, resurfaced flywheel, front wheel studs, plugs, replaced sc coupler, sc oil, drivers axle, belts, outlaw engineering intake manifold/throttle body/iacv gaskets, sc pulley, keyways, all boots and probably missed a few things.
Thanks for the read and any advice would be well appreciated.
Old Feb 20, 2008 | 12:06 AM
Haleiwa-Brando's Avatar
Default Re: #1261 is running again -WOT! (dsav4shawn)
You kind of hinted an answer at your own question. You mentioned finding a 'competent hondata tuner' in your area.
That is more or less the issue. Rather than getting a system and finding a tuner for it, it is probably best to find a tuner in your area who kicks ***, then inquire on what he/she likes to tune and go with that.
I've learned, and payed dearly for going the aforementioned route. Not so much fun. Nope.
Old Feb 21, 2008 | 07:00 PM
dsav4shawn's Avatar
Default Re: #1261 is running again -WOT! (Haleiwa-Brando)
100% running/driving last night.
I put 46.8 miles on her last night and on the way home my front pad destroyed itself and then ate the rotor.
Argh. -just wanted to vent.
Old Feb 21, 2008 | 10:41 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dsav4shawn &raquo;</TD></TR><TR><TD CLASS="quote">100% running/driving last night.
Argh. -just wanted to vent.</TD></TR></TABLE>
What pads are those, so I know to never get a set
With you driving around, I assume you got the car tuned?
Old Feb 22, 2008 | 05:21 AM
U N S E E N.'s Avatar
congrats man!! im about to get mine running in the next two weeks, we should meet up and snap some pics!
Old Feb 22, 2008 | 05:49 AM
dsav4shawn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by U N S E E N. &raquo;</TD></TR><TR><TD CLASS="quote">congrats man!! im about to get mine running in the next two weeks, we should meet up and snap some pics!</TD></TR></TABLE>
whereabouts... and I now have more knowledge of this motor fixing concept. LMK if you need a hand.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando &raquo;</TD></TR><TR><TD CLASS="quote">
What pads are those, so I know to never get a set </TD></TR></TABLE>
Can't recall... I'll inform you tonight. I bought new autozone rotors and ceramic pads last night. Changing them out tonight.
With you driving around, I assume you got the car tuned?</TD></TR></TABLE>
It is still tuned at 5lbs (old tune) however, keeping it under 3500 rpms and not providing boost to the motor keeps it running at a good a/f. I've spoken to a few jrsc s200b guys and they state that I'm fine till it breaks in -then tune.
Old Feb 22, 2008 | 09:03 AM
last time i talked to you i was living in ecity, but now im up in portsmouth. im all done i just need to order a few more parts.
Old Feb 22, 2008 | 10:13 AM
JjuuN R's Avatar
Damn!! What do you think caused this to happen? Maybe they weren't seated? Just seems kind of random for that to happen.
Old Feb 22, 2008 | 10:35 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dsav4shawn &raquo;</TD></TR><TR><TD CLASS="quote">It is still tuned at 5lbs (old tune) however, keeping it under 3500 rpms and not providing boost to the motor keeps it running at a good a/f. I've spoken to a few jrsc s200b guys and they state that I'm fine till it breaks in -then tune. </TD></TR></TABLE>
I've heard both sides. One being what you've said that is quoted and the other being more or less the Import Builders method of establishing A/F on the first start up followed by WOT (done by the tuner) to seat the rings in regards to how the car will be driven.
Old Feb 22, 2008 | 11:07 AM
robfrmny21's Avatar
inspect your plugs regularly to make sure things are running right seeing that you did not tune it yet
Old Feb 22, 2008 | 01:14 PM
dsav4shawn's Avatar
Default Re: #1261 is running again -WOT! (JjuuN R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JjuuN R &raquo;</TD></TR><TR><TD CLASS="quote">
Damn!! What do you think caused this to happen? Maybe they weren't seated? Just seems kind of random for that to happen.</TD></TR></TABLE>
It was late at night when I put it back together... I'm 99% confident that I properly seated them. Perhaps the year of sitting in the elements didn't help. I'll be out there in about 2 hours replacing both front rotors/breaks/hardware. -I'll see exactly what happened. on me if I f'd up a nice slotted rotor due to rushing it (probably not the case).
Old Feb 22, 2008 | 01:26 PM
totsie7944's Avatar
It was late at night when I put it back together... I'm 99% confident that I properly seated them. Perhaps the year of sitting in the elements didn't help. I'll be out there in about 2 hours replacing both front rotors/breaks/hardware. -I'll see exactly what happened. on me if I f'd up a nice slotted rotor due to rushing it (probably not the case).</TD></TR></TABLE>
eh slotted rotors are overrated man. Stick with Autozone rotors lol
Old Feb 22, 2008 | 02:06 PM
dsav4shawn's Avatar
Default Re: #1261 is running again -WOT! (totsie7944)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by totsie7944 &raquo;</TD></TR><TR><TD CLASS="quote">
eh slotted rotors are overrated man. Stick with Autozone rotors lol </TD></TR></TABLE>
True... autozone rotors ftw and in hand.
Well... the 1% chance that I f'd up is what happened. I'm not gonna actually divulge the truth. Let's just say that I'll put the new rotors and pads on this weekend. Kinda po'd right now. I need a .
AccordEX1991
Honda Civic (2001 - 2005)
21
Feb 27, 2016 03:27 AM
MalcolmV8
Sep 27, 2012 05:07 AM
ludeboy555
Feb 11, 2004 10:34 PM
jbbauer7
Oct 21, 2003 06:04 PM
(__________)
Jun 30, 2002 07:48 PM
