1996-2000 ek9 navigation
I have a question which no one seems to be able to answer i've searched many forums and i have yet to get the answer... Can anyone show me or tell me what wires to splice into what or tell me if its even possible..... im trying to get this thing running and there alot of people who have this setup installed but i want to know if it can be spliced into stock wiring with what i have................ all i have is the navi and the wires that connect to it............ let me know if you guys know where a wiring diagram is or how to find one...
Modified by droopyli05 at 6:35 AM 2/20/2008
Did you try searching in the Honda Civic/Del Sol (1992-2000) forum, in BOTH recent and Archived content with and without searching in the post title?
https://honda-tech.com/zerosearch
yes i've reviewed the posts there but there still isnt any details on how to splice anything or any help as to a wiring diagram what you see in the pictures is all i have
I heard the navigation dosnt work but turns on. the climate control should work.
how about looking at where your stock wires goes into your stock climate and go from there.
oh check this thread out. havnt looked but you can.
https://honda-tech.com/zerothread/1901270
To wire that up you need the tape player that goes with it. I know because I have one and had loads of trouble wiring it up. Your factory harness is connected to your tape player and the tape player connects to your screen. But the screen also has a seperate plug for power. The little black plug that is on the upper left hand corner of the device is the power plug, the one with maybe 7 or 8 wires, it looks like you already cut yours. I have never tried plugging in the screen alone but it might work but you won't get any sound without the tape player seeing that the audio comes out of there. The navigation will never work here in the states but everything else will. I didn't post a pic because this is giving me a headache. I'll check in a couple of days to see if this was any good. GOOD LUCK.
actually this was some help. but i have another question, can i use any honda factory radio, something like this that connects to a seperate cd player
The Honda factory radio can be used. You just wont be able to control the audio controls on the screen. I highly suggest you use the lower tape deck. All the audio logic boards are inside it. <--Big Hint
Andre Goncalves
Honda Civic (2006 - 2015)
Nov 13, 2017 05:27 PM
rysingsun86
Dec 20, 2005 10:17 AM
