FS: Enjo H series Honda Motor Mounts
Old Feb 19, 2008 | 06:47 PM
SpoonSleeper's Avatar
Default FS: Enjo H series Motor Mounts and OmniPower Coilovers EG/DC/DelSol
*****[NIB] set of Enjo motor mounts for any F series or H series swap into any EG/Del Sol/DC Integra. $275.00+shipping*****
Up for sale is a set of used Omni Power Coilovers that were on my daily driver for roughly 8k miles. They are a little dirty in the pictures, as you can see in the pictures some of the powdercoating on the springs is starting to come off on the two front springs. I only used these to drop my car roughly an 1 inch and I have not stressed them more than that. These sell for $799.99 off of Omni's site. Also they have the new cup, re-designed and re-enforced front collars as you can see from the pictures. Comes with everything shown in the pictures: 4 coilovers, 2 adjusters, 1 set of directions. $475.00 + shipping
These should fit all 94-01 Integras and 92-95 Civics.
Acura Integra 1994-2001 Full Coilovers
Sport Version (F=12k R=10K)
DCFCS-SP $ 799.99
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Omni-Power shocks with Tilyte Technology feature qualities only found in the most elite suspensions on the market. Developed by Omni-Power, Tilyte is a system of components that works together symbiotically to create a unique blend of damping, which allows a much better foot print over virtually any road condition. Starting with a new proprietary spring steel for our valve shims, allows approximately 35% better fatigue resistance than other spring steels, while giving more consistent performance over a longer period of time. These shims are perfectly matched in thickness to each applications spring rates and suspension geometry, and then precisely preloaded on Omni-Power designed Tilyte pistons. The new Tilyte piston design allows the shock damping to respond to the slightest movement and provides smooth transitions from low speed to high speed. We use Fina shock oil, with nearly unmatched operating temperature ranges and highly resistant to foam formation, that floats on an intermediate piston supported by high pressure nitrogen gas. This design provides ultra smooth low speed damping and aggressive high speed control with a smooth transition. Although the shock damping is not adjustable it far exceeds the performance of several claimed 24/32/36+ way adjustable shocks. Omni-Power coilovers with Tilyte technology hold numerous world records in the most competitive classes of Drag, Auto-X, and Road Racing for their reliability and unparalleled traction. The new Omni-Power full coilovers with Tilyte technology have been designed to perform consistently over a longer period of time and thousands of miles of abuse, while offering maximum traction and tire foot print control. We offer a 2 year warranty on all of our suspension systems and stand behind our products 110%.</TD></TR></TABLE>
The worse part of the powdercoating flaking off at the bottom of the front spring.
Any questions feel free to hit me up, I'll do my best to answer all of them quickly. :yes:
*****I also have an 1997 Acura Integra LS head with roughly 63K miles on it. I can snap pictures for interested people. $100*****
Modified by SpoonSleeper at 10:40 PM 2/19/2008
Modified by SpoonSleeper at 11:31 PM 2/19/2008
Modified by SpoonSleeper at 3:46 AM 3/16/2008
Old Feb 19, 2008 | 07:17 PM
eg6low-buck's Avatar
Default Re: FS: Enjo H series Honda Motor Mounts (SpoonSleeper)
BUMP!!!
Old Feb 19, 2008 | 07:34 PM
Default Re: FS: Enjo H series Honda Motor Mounts (eg6low-buck)
Thanks for the bump
Someone jump on these:
"ENJO™ H-SERIES ENGINE MOUNTS - Platinum Series™
The EM92 from ENJO™ provides precise, 100% bolt-on installation of H22, H23 or F22 engines into the 92-95 Civic, 93-97 Del Sol and 94-01 Integra (no welding required), while offering adequate hood and power steering clearance. Made from top grade steel, which absorbs and transfers power, these mounts are laser cut and jig welded to ensure fitment accuracy. Powder-coated in silver with red polyurethane inserts. Each kit includes a pair of ENJO™ Performance Gloves. H-SERIES INTO 1992-95 HONDA CIVIC/1994-97 DEL SOL/ 1994-01 ACURA INTEGRA For installation of H22, H23 and F22 engines.
* Includes: Engine Side Mount
* Transmission Mount
* Rear Transmission Mount "
Old Feb 19, 2008 | 10:09 PM
Bump for the night crew
Old Feb 20, 2008 | 11:22 AM
Someone buys these, thats over a $100 less than what I paid for them and theyre still BRAND NEW.
Old Feb 21, 2008 | 03:53 PM
Old Feb 24, 2008 | 11:45 AM
Bump
Old Mar 8, 2008 | 01:19 PM
Old Mar 16, 2008 | 12:45 AM
Bump looking to sell
Old Apr 9, 2008 | 10:12 AM
weev's Avatar
Default Re: FS: Enjo H series Motor Mounts and OmniPower Coilovers EG/DC/DelSol (SpoonSleeper)
are these mounts still available?
MasterFunk
Oct 5, 2016 07:13 AM
turboek98
Oct 4, 2012 08:21 PM
civicmotorhead
Nov 16, 2010 02:42 PM
drunknbass
Jan 13, 2005 11:15 PM
