Defroster question? (right forum?!?!)
Not sure if this is in the right section but hopefully I can get an answer. I recently helped my friend out with replacing his top on his s2k with a robbins glass top. The old top had a plastic window (ap1) and the car is not wired for defrost, the new top has defrost tho and I'm trying to find a way to hook it up. Is it as simple as just wiring it up to a switch or do I need some type of module. Thanks in advance.
You will need a "module", the defrost is "high current" so a relay is needed
the relay needs to be controlled by a timer, [you can buy the timer module]... http://www.stealthlabs.com/relaystimers.html and a simple momentary, [push button] switch to trigger the timer.
94
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm »</TD></TR><TR><TD CLASS="quote"> Yes, but will you, [your friend] remember to turn it off once the window is defrosted?
94</TD></TR></TABLE> You got a point there, Its up to him if he wants to get the timer I'm just the installer. Thanks.
ChicagoMike
Mar 14, 2006 08:07 AM
tianporn
Audio / Security / Video
15
Feb 21, 2005 07:56 PM
