How well does paint take to carbonfibre bonnets?
Just curious, really.
I've been toying with the idea of getting a carbonfibre bonnet, but I generally prefer my car to be discreet in its appearance. So if I were to get one it must be painted. However, I wonder if there are any common problems associated with painting carbonfibre such as poor adhesion, chipping, difficulty in colour-matching, etc.
I wouldn't think that the weave would show since the resin smooths everything out, but it does bring up the question of consistency of the resin itself (i.e. ripples that would normally be hidden by the weave pattern?). I suppose careful preparation should eliminate that as a problem though.
wouldn't it look a little lumpy due to the weaves?
Speaking of fibreglass, why not get a fibreglass hood instead, comparable weight and half the cost. If you are concerned with strength, I think both types of hoods would break in an impact.
I haven't looked into fibreglas because I've never seen a fibreglas bonnet that retained the stock appearance. They've all got scoops or vents or some other unnecessary visual excitement going on.
Here's an idea, I think this is what Realtime R's do but why don't people cut off the under support of their stock hoods and put some hood pins on
When you add it up, paint weighs a little bit Den... but I suppose you're right, it still is lighter than stock.
... seriously if your this concerned about 0.2 lbs of weight...you better fast before you do any racing.... 3 day fast to clean yourself of all food in the system, and be sure to drink very little water...
Mr. Vapor
Feb 12, 2007 02:45 PM
ThisLittleSleepeR
12
Dec 6, 2004 01:31 PM
Even better
