D16Y8 D16 Partout *Head, Tranny, Bored Block, Vitara 75.5s, Intake Mani* and more
Recently I have purchased a complete D16Y8. I pulled it apart and had some machining done to it to get it ready for the turbo build I had in mind. Now I've decided to go another route. Take this stuff off of my hands! Pictures at bottom of post
I also have a lot of miscellaneous bolts, brackets, sensors, covers from the motor. If you need anything let me know.
***Will ship at buyers expense.
-Bare block cleaned and bored .020 over and matched to pistons *There is no Scaring on the walls, It's lead from a pencil being run down the length of the wall. $140
-75.5mm Vitara G16 pistons and pins w/ hastings rings ^^matched^^ for a P2W clearance of .003 (good for up to 450 HP)
$130
-Freshly milled head still assembled (no IM or exhaust mani) $115
-Tranny w/clutch, flywheel, PP (~130,xxx-ish miles. Told it ran perfectly when pulled from the car, no grinds whatsoever) $130
-Intake Manifold w/ Throttle Body, fuel rail, and injectors $125
-Crankshaft that has been reconditioned to .010 under on the rods and mains $75
-Full bottom end rebuild kit that includes all gaskets necessary to do a complete bottom end rebuild (Head gasket and VC gasket included), ACL bearings, OEM timing belt and water pump. $150
-OEM oil pump $25
-Oil pan and Pickup $35
-Dizzy and wires $35
-Tranny mount + Bolt$15
-Bilstein EG Civic lowering springs $40
-AEM Bypass Valve *new* $30
-Alternator $SOLD
-Crank Pulley $OBO
Pictures:
All items are sold as-is and paypal is preferred.
Paypal is soccerpredator2003@tds.net.
Modified by BEYAAAH at 2:06 PM 2/20/2008
Modified by BEYAAAH at 1:35 PM 2/22/2008
Modified by BEYAAAH at 1:36 PM 2/22/2008
$130
-OEM oil pump $25
-Alternator $SOLD
-Crank Pulley $OBO
Pictures:
how much to have the head shipped to NJ 08514.
does it come with camshaft, sensors and vtec solenoid?
head SOLD! to me
thanks a million. looks great and is in great working condition. Awesome seller!!!!!!!
Do you still have the block, pistons, rings, crank, bearings? Are the bearings .010 to match the crank/rods?
sundownz
Jul 7, 2008 01:57 PM
aktuning
Oct 22, 2007 07:02 AM
