h22 all motor....ecu?
Old Feb 19, 2008 | 04:11 PM
2.3vtec_stroker's Avatar
Default h22 all motor....ecu?
i have an an h22 and im not sure what to do for an ecu. right now i have cold air, full exhuast, h23 crank and rods, light porting, 450cc dsm injectors, and i plan to install my skunk2 intake mani and throttle body soon. this is my first project and i have failed to invetigate the computer portion of the build. i was thinking hondata ecu but i didnt know if there was a more cost effective option out there...... open to suggestions. thanks
Old Feb 19, 2008 | 05:22 PM
awdgsx96's Avatar
Default Re: h22 all motor....ecu? (2.3vtec_stroker)
P13 is the ECU I've seen most used with H22's
Old Feb 19, 2008 | 05:52 PM
my9thtry's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by awdgsx96 &raquo;</TD></TR><TR><TD CLASS="quote">P13 is the ECU I've seen most used with H22's</TD></TR></TABLE>
u cant tune a p13
how much farther do you plan on going with your build? what pistons are you using?
Old Feb 19, 2008 | 06:01 PM
JayWest's Avatar
Default Re: h22 all motor....ecu? (my9thtry)
what car is this in?
p28 is what most swapped cars run
Old Feb 19, 2008 | 07:20 PM
Default Re: h22 all motor....ecu? (JayWest)
this motor is in a 94 prelude that used to have an h23 in it. im not sure how much further i want to go. im going to put the intake mani and throttle body on for sure. im not sure what i wanna do after that. right now i just want to be able to get it running right. i guess im just trying to figure out what its going to cost to get it tuned as is vs how much it will cost to get it tuned with room to play later.
Old Feb 19, 2008 | 07:23 PM
if i get the p28 ecu what else will i need to get it properly tuned. wideband, cam gears..ect........?
spoon93
Dec 27, 2007 05:57 PM
mck26
Oct 9, 2005 12:47 PM
92LudeSI
Mar 29, 2005 04:45 PM
92hondalude
Aug 6, 2004 08:42 AM
AndyD
Dec 24, 2003 09:04 AM
