p1457 error code
Old Feb 19, 2008 | 01:29 PM
sdfghjkqwer's Avatar
Default p1457 error code
I got the p1457 on my 99 civic ex
Whats the best place to take for a diagnosis? I am located in boston, massachusetts area. Dealership quoted me $100, is it a good price? Can I trust them?
Any help is appreaciated, thanks.
Old Feb 19, 2008 | 01:33 PM
SilverBulletY8's Avatar
Default Re: p1457 error code (sdfghjkqwer)
any local parts dealer should be able to hook into you ECU and pull codes... many will do it for free...
Old Feb 19, 2008 | 01:35 PM
98CivB18C's Avatar
Default Re: p1457 error code (SilverBulletY8)
take it to the zone, auto zone
they check your CEL for free
use red search button on the top for CEL codes.
Old Feb 19, 2008 | 02:23 PM
nub's Avatar
nub
Default Re: p1457 error code (98CivB18C)
p1457 evap system leak canister area-- look for cracks on the canister disconected or damaged lines
Old Feb 19, 2008 | 08:00 PM
Thanks for all the replies
I know its the canister..Unfortunatelly i dont have a lifter, tools or time to look at it my self. Whats the best place to check for leaks?
Old Feb 19, 2008 | 10:24 PM
NOFX's Avatar
H-T White Ops
Autozone is selling an OBDII scanner for $40 right now too. (Regular price is $69.99.) It's just a basic model that reads the code (no explanation on the screen) and erases codes, but it works.
It comes with a book with explanations for all the codes.
But yes, they will scan your car for free too. Then they'll give you a little print out that says what the code is, what it means and the most common problems that cause that cell.
Old Feb 27, 2008 | 11:32 AM
Ok I found the problem and I replaced the 2 way valve.
Almost 300 miles passed and the light didn't go on.
Is it safe to take the test?
Old Nov 30, 2011 | 09:35 AM
koreboy's Avatar
Thanks for the info!
How did you know it was the two way valve that was causing the problem?
I have the same code and the mechanic at the Honda dealership told me that this error would not harmfully affect my engine.
Old Nov 30, 2011 | 09:51 AM
Shooktd's Avatar
where did you get the valve? part number? i need the same one
Old Dec 23, 2011 | 06:49 PM
lawnguybri's Avatar
Lmao...I'm there too. How can the two way valve be tested? And where do I find one?
Old Dec 24, 2011 | 04:07 AM
HondaPartsHero's Avatar
Technical Hero
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/evap-emissions-p1457-check-engine-light-99-civic-si-2558768/
professorman
Feb 10, 2014 04:29 PM
jillygirl13
Honda CR-V & Element
Jun 11, 2012 06:25 PM
iconz116
Jan 8, 2005 12:20 PM
Nighthawk GS-R
Oct 5, 2001 10:05 AM
