Symptoms of bad spark plugs ( not wires) ??
Old Feb 19, 2008 | 12:58 PM
matmcg's Avatar
Default Symptoms of bad spark plugs ( not wires) ??
what are the symptoms especially in cylinder 1 and 2
Old Feb 19, 2008 | 01:20 PM
98BabiGs-T's Avatar
Default Re: Symptoms of bad spark plugs ( not wires) ?? (matmcg)
... Just check the color on the tip and if its properly gapped. Other then that I don't know how.... maybe misfiring and what not.
Old Feb 19, 2008 | 01:23 PM
matmcg's Avatar
Cuz my car wont start
Changed my Dizzy
Main relay is okay
checked fuses
Checked for spark from wires
Got it started one time and it really really idled badly was shaking alot tried to drive and it turned off
sometimes it semi starts but when pressing the gas to try to keep it alive it get weak and dies
Old Feb 19, 2008 | 02:00 PM
matmcg's Avatar
UP
Old Feb 19, 2008 | 02:52 PM
matmcg's Avatar
bump
Old Feb 19, 2008 | 03:17 PM
JasonST's Avatar
Default Re: (matmcg)
Check to see if u get spark, fuel, and compression, then go from there.
Old Feb 19, 2008 | 03:22 PM
matmcg's Avatar
i get spark out of the wires
my car can turn on everyonce in a while but with really bad idle and shaking
Old Feb 19, 2008 | 03:37 PM
denieone's Avatar
I would suggest checking your timing
Old Feb 19, 2008 | 04:04 PM
matmcg's Avatar
Default Re: (denieone)
how do i check the timing?
Old Feb 19, 2008 | 04:28 PM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matmcg &raquo;</TD></TR><TR><TD CLASS="quote">how do i check the timing?</TD></TR></TABLE>
http://www.c-speedracing.com/h...g.php
Things to ask yourself:
Does the fuel pump always prime? (You should hear a slight buzz from the rear right after the key is turned to the run position but the car is not cranked.)
Are all of your injectors firing? Are the plugs gas soaked?
micah13x
11
Apr 14, 2011 03:09 PM
psegs80
Jul 29, 2005 02:32 PM
CustomTeggy44
Apr 29, 2004 10:38 PM
95dx
13
Nov 25, 2003 01:29 PM
g2turbo
Sep 17, 2003 08:31 PM
