OBDII H22a4 Subharness to Engine harness PinOuts (shocktower connectors)
this diagram represents the subharness (cabin) side of the connector and looking INTO the connector
__________________________________________________ ______
Connector "7P" - Blue - 14pins - female
----- 1. Dead Plug ground -----2. XXXX -----3. ????? -----
--4. INJ4 --------- 5. INJ3 -------- 6. INJ2 -------7. INJ1 ---
--8. PG1 --------- 9. PG2 -------- 10. VSS ------ 11. ICM
------12. IGP1/IGP2 ------ 13. XXXX ------14. IAT
__________________________________________________ _______
Connector "P11" - blue - 14 pins
-------1. CKP P ------2. TDC P -------3. CYP P ------
4. LG2 ------5. IACV ------- 6. IAB -------- 7. VTS (vtec)
8. ??? ----- 9. ????? -------10. Alt FR sig ----11. Alt Ctrl ---
----- 12. CKP M -----13. TDC M ------ 14. CYP M ----
__________________________________________________ __________________
Connector "Y04" - 8 pins
1. Reverse lights (female) ------ 2. Po2 heat --------3. Po2 ------4. LG2
5. Reverse lights (male) ------- 6. ??????? ----------7. EGR (lift) --- 8. ???
__________________________________________________ ___________________
Connector "2P" - 10 pins
-------1. VCC1 (MAP) -----2. MAP ------- 3. SG1 -------
4. ECT --------- 5. VCC2 (TPS) ---- 6. TPS -------7. SG2 ---
8. ICM (blue) ------- 9. PS switch -------- 10. Vtec Pressure
All these threads, are great info.. i cant tell you how many times I could of used one of these and saved myself hours from searching and looking for it in the hlems.
These should go in the FAQs under a new section titled PINOUTS
GRAVEDIGGER
Aug 27, 2003 12:41 PM
