FS OR TRADE FOR PAINTJOB/ Body work built 98 spec ITR B18c 207+ whp
I had bought this motor from kevedge with plans on putting it in my EG but never found the time. and now it is time to move on. The motor was built by Jay Smith. Since being built the piston rings were replaced about 3000 miles ago. The setup made 207hp /148tq to the wheels tuned on VAFC. Im sure a better tune and better header could easily push more than 215 to the wheels.
2,100 dollars. thats two thousand one hundred dollars
or trade for a good paint job and a little bit of body work on my EG
the head
B16 head w/P&P
Supertech valve train
Buddy Club Spec 4 Cams
Spoon Gen1 Cam Gears
AEBS Intake manifold
RC 310 Injectors
Tapered ITR Throttle Body to match manifold
Brand new Dist.
NGK Blue Wires
BLOCK
98' Spec ITR Block
Balanced and Blue Printed
Replaced the pistons rings about 3k miles ago
CTR Crank Pulley
Spoon Race Clutch and Flywheel
Modified by OGegg at 7:54 AM 2/20/2008
Modified by OGegg at 9:17 PM 2/24/2008
the head
B16 head w/P&P
RC 310 Injectors
Brand new Dist.
NGK Blue Wires
BLOCK
98' Spec ITR Block
CTR Crank Pulley
where u located could hook you up with bodywork and paintjob..not a comeplete inside too but only the exterior i could prob work out...
l2Y4N
Jun 13, 2011 11:04 PM
b19coupe
85
May 1, 2007 07:27 PM
Kevedge
Jul 29, 2006 08:24 AM
