does anyone know what this spray i looking for is called
there is a spray that you can put a bare metal and then wipe it off to prevent rust or if you know of Any thing else i can use would be help full
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Goullish »</TD></TR><TR><TD CLASS="quote">Um, oil? Just take some lube spray, spray it on, and wipe the excess.</TD></TR></TABLE>
i don't wont to create more work for my self latter ween it comes time to pant the car
here u go man i use this stuff but if u look on this site u might be able to find what ur lookin fore
http://www.eastwoodco.com/shop...=1134
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by new2novas »</TD></TR><TR><TD CLASS="quote">its called pickle or something to that effect..do NOT use por15 on bare metal</TD></TR></TABLE>
Why is that.
The makers of POR15 recommended it to me as long as the grit used to sand it was between 36 to 60
Why is that.
My favorite is LPS #3. Ace Hardware and Harbor Freight carry it. I use it on my drill press main shaft, table saw top and any bare metal prior to painting. It just plain works. This stuff was sprayed on the side of a Coast Guard Cutter and was still there after 2 years of constant salt water attack. It is not water soluble and only leaves a thin film. They also carry LPS #1 = almost like WD40 and LPS #2 = somewhere in between. Cosmoline works great but can be difficult to wipe off. Break parts cleaner works good.
Later
Later
i built the front clip on my nova and used por15 on the whole thing, brand new metal that was scuffed up...few months later i nicked the paint and went to pick off the peice and it peeled a huge section, then i could just peel large sections off, some stuck (pain in the *** to remove) some didn't....go to http://www.stevesnovasite.com and search the forums there and you will see other that have been disappointed...of course they recommend it, sometimes its good too, i use it, just not on bare metal...just my personal opinion
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by damnraz »</TD></TR><TR><TD CLASS="quote">LPS Rust Inhibitor</TD></TR></TABLE>
thanks i believe that's what im looking for
The answer is, if it prevents rust, it leaves something on the metal and you want to make sure that is paintable and/or never ever coming off. Personally I would just primer it.
http://www.grainger.com/Grainger/items/6Y745
Waxy Film Stops Rust and Corrosion and Provides Protective Coating for Up to 2 Years
Sounds like good ****.
some other stuff too
http://www.schafco.com/cosmoline.asp
Revolemilbus
11
Aug 1, 2006 06:51 PM
EnKidu
16
Oct 15, 2004 09:59 AM
