b18a1 throttle body Help need some Info ???
My motor is out of the car and it's been a while... but I think those are coolant lines? One line comes from the head area and the exit line goes back toward the block.
Sorry I'm not much help, I haven't touched my car in over a year so I'm going off of memory. I believe those are not a line that you *have* to have hooked up to drive it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sph33r »</TD></TR><TR><TD CLASS="quote">My motor is out of the car and it's been a while... but I think those are coolant lines? One line comes from the head area and the exit line goes back toward the block.
Sorry I'm not much help, I haven't touched my car in over a year so I'm going off of memory. I believe those are not a line that you *have* to have hooked up to drive it. </TD></TR></TABLE>
yeah there coolent line's i found out that the one closest to the IACV goes to the throttle body towards the left side , but i dont know where the other one on the right connect's to
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC_Du_Ma_Mai »</TD></TR><TR><TD CLASS="quote">the other coolant line connects to the head. just look for a line that is not plugged around that area.</TD></TR></TABLE>
i checked by the intake mani but there's nothing unplugged unless there mixed around, on the FITV there's a coolent line there goes to the intake manifold already
the one ur talkinga bout
ok, take a look at the big fat coolant line running from the radiator to the head. the opening that the line is connected to on the head should have 2 nozzles sticking out of it. the left nozzle is a coolant nozzle and should have a line attached to it. follow that coolant line to where it ends and that is where you attach the coolant line on the tb.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC_Du_Ma_Mai »</TD></TR><TR><TD CLASS="quote">ok, take a look at the big fat coolant line running from the radiator to the head. the opening that the line is connected to on the head should have 2 nozzles sticking out of it. the left nozzle is a coolant nozzle and should have a line attached to it. follow that coolant line to where it ends and that is where you attach the coolant line on the tb.</TD></TR></TABLE>
okay i followed the radiator hose that connect's to the head, and there's a lil nipple on the side from where the hose clap is
good **** man thanks that **** was hidden i couldnt find it lol so all the other one's are hooked up fine ?
well i connected all the line's now and i still have this damn problem it bog's when i give it gas and it still kinda idle's high 1500rpm and wont drop i give it gas and it burly wants to go up i already changed the IACV & the FITV i dont know what else it could be ? someone told me it could be my TPS but would that make it bog that bad ?
you should check the TPS to see if it is in the correct position. search for TPS problem or TPS voltage and you should find some answers.
Edit: didnt see the other thread
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC_Du_Ma_Mai »</TD></TR><TR><TD CLASS="quote">you should check the TPS to see if it is in the correct position. search for TPS problem or TPS voltage and you should find some answers.
Edit: didnt see the other thread</TD></TR></TABLE>
the TPS should be in its right position its OEM i havent removed it i didnt know the TPS would make it bog this bad damn sensor's
I requested a short story for a title.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LoW ToNE »</TD></TR><TR><TD CLASS="quote">
the TPS should be in its right position its OEM i havent removed it i didnt know the TPS would make it bog this bad damn sensor's </TD></TR></TABLE>
oh yes. the tps is one little pain in the ***.
I had a very similar problem after dropping a B18 into a civic. I finally figured out that the MAP and TPS sensors were plugged in the opposite plugs. (switched around) You might check that. Pain in the *** to get to but an easy fix.
