Dumb Question
Old Feb 18, 2008 | 06:39 PM
georgeseq's Avatar
Default Dumb Question
How do you really know when your inner or outer tie rods are gone ?
Old Feb 18, 2008 | 06:40 PM
ke98248's Avatar
Default Re: Dumb Question (georgeseq)
have you looked at them?
Old Feb 18, 2008 | 06:45 PM
georgeseq's Avatar
Default Re: Dumb Question (ke98248)
yea, but what does it really do when it goes bad. specially when you drive ?
Old Feb 18, 2008 | 06:47 PM
2redstars's Avatar
jack the car up to get that wheel off the ground, grab the wheel on each side, try to move it in and out. if there is play, then you need to replace the tie rod.
Old Feb 18, 2008 | 06:53 PM
Archidictus's Avatar
Unceasing Measure
Default Re: Dumb Question (2redstars)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2redstars &raquo;</TD></TR><TR><TD CLASS="quote">jack the car up to get that wheel off the ground, grab the wheel on each side, try to move it in and out. if there is play, then you need to replace the tie rod. </TD></TR></TABLE>
That's really not a good way to determine tie rod failure. Usually, if you can get play in the wheel without using the steering rack, it's the wheel bearing.
Look at your tie rods. If the stud is cocked at a funny angle and there's grease all over the place, it's likely done for. If you turn your wheel while driving and there's a lot of slop in the handling, you'll want to check it out. Take pictures and we'll let you know.
Old Feb 18, 2008 | 06:56 PM
2redstars's Avatar
Default Re: Dumb Question (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">
Look at your tie rods. If the stud is cocked at a funny angle and there's grease all over the place, it's likely done for. If you turn your wheel while driving and there's a lot of slop in the handling, you'll want to check it out. Take pictures and we'll let you know.</TD></TR></TABLE>
thats basically what i just said. except your grabbing the wheel and feeling for slop. and by doing this you can see what has play, you can do the same for the upper and lower ball joint.
jonyi27
Dec 9, 2012 10:55 AM
kelley_james
Jul 10, 2012 10:42 PM
boost4life1
Nov 17, 2011 02:53 PM
09egkid
Aug 6, 2010 02:54 PM
unknown0001
Sep 22, 2006 12:02 PM
