LS and GSR ignition Coil/ ignitor the same?
are LS and GSR ignition coil and ignitors the same? My car's not starting, and instead of going out to spend 200 dollars in parts, I want to swap in the LS dizzy internals to see if it will work. I did a search, but only came up with gsr, si, itr, prelude, and F22 internals.. nothing on LS.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by db1_jdm »</TD></TR><TR><TD CLASS="quote">check for yourself, if they have the same part numbers or if they supersede eachother.
acuraautomotiveparts.org</TD></TR></TABLE>
what do you mean by supercede each other?
2000 LS:
30130-P75-006 IGNITER UNIT ASSY.
30510-PT2-006 COIL ASSY., IGNITION
30100-P75-A03 DISTRIBUTOR ASSY. (TC-08A) (TEC )
99 gsr:
30130-P73-A01 IGNITER UNIT
30510-P73-A02 COIL ASSY., IGNITION
30100-P73-A02 DISTRIBUTOR ASSY. (TC-08A) (TEC)
NOTE: the 2 dizzy housing I have do not look identical, but the coil does. the ignitor looks to be a different color, but physically looks similar in dimension and shape.
2000 LS:
99 gsr:
006, 30130, 30130p73a01, 30130p75006, 30510p73a02, acura, coil, gsr, ignition, ignitor, integra, ls, p75, same, tc08a
