NO POWER TO STARTER
I WENT TO START MY CAR YESTERDAY AND NOTHING.. I GOT POWER TO EVERYTHING LIGHTS RADIO ETC.. I CHECKED ALL OF MY GROUNDS FUSES, RELAYS, CHAHGED THE STARTER WITH A NEW ONE.. DONT NO THE PROBLEM COULD IT BE THE IGNETION TUMBLER OR OR THE SAFTY SWITCH ON THE CLUTCH PEDAL PLEASE HELP
2 things ive encounterd......hook up another battery just to rule out the battery, sometimes if my battery is too low everything else works but the starter. also try pumping the clutch pedal, my clutch switch dosent start unless i pump it to the right spot
Quick way to check if it is the clutch switch is to unplug it and jump the connector...if it starts then your switch is junk, if it still doesn't then the switch is probably good.
magicmyst98
14
Sep 2, 2013 12:06 PM
zerovandez
Apr 1, 2011 01:05 PM
redefsir
19
Jan 28, 2010 08:46 AM
