transmission help
Old Feb 18, 2008 | 03:51 PM
balili89's Avatar
Default transmission help
When i shift it is so stiff and not smooth at all and i just flush the oil but its still like that. Where can i get a new transmission for my 98 integra ls and how much you think it will cost me
Old Feb 18, 2008 | 03:54 PM
kchungb17a's Avatar
Default Re: transmission help (balili89)
You may not need a new tranny. Does this happen in all gears? If so, it could be that the clutch is about to go.
Old Feb 18, 2008 | 04:11 PM
balili89's Avatar
Default Re: transmission help (kchungb17a)
it happens in all gears. it stiff and not smooth at all. How do i know when i need to change my clutch. does a bad cluth make the shifter stiff?
Old Feb 18, 2008 | 06:39 PM
96cgpteg's Avatar
look up under the dash on the driver side of your car... Look at the clutch pedal and trace it up... you will see a rod connected to your clutch pedal, that runs from the pedal to your firewall... look at this area and see if you see any fluid that looks like oil, if you do indeed see some fluid you need a new clutch master cylinder... When these go out they make it hard to get in and out of gear, especially 1st gear and reverse...
Old Feb 18, 2008 | 06:51 PM
balili89's Avatar
Default Re: transmission help (96cgpteg)
yeah it is first and rev. that is hard to shift? so its better just getting a new clutch then huh? What do you think of the CLUTCH MASTERS clutch? And i know this is a noob question but ill rather ask to know is the 98 integra ls a push clutch or Hydraulic Clutch?
Old Feb 18, 2008 | 07:16 PM
i getz da chewin's Avatar
Hydraulic
i like my exedy stage 2 clutch pretty well...look into that also
Old Feb 19, 2008 | 09:36 PM
balili89's Avatar
i took it to the shop today and they said it has a internal problem. so i guess i need to rebuild it or just buy a used one
lxdriver
Feb 26, 2011 07:28 PM
havikprelude
Transmission & Drivetrain
Jan 20, 2010 09:32 AM
hpimichael02
Oct 31, 2008 09:46 AM
antoneexx
Apr 6, 2007 01:50 PM
ludelvr
Sep 12, 2003 04:20 AM
