Honda S2000 Honda S2000
can i run a +35mm offset?
Old Feb 18, 2008 | 03:12 PM
projektcivic's Avatar
Default can i run a +35mm offset?
18x9.5 (rear)
and 18x8.5 (front)
would i have to run spacers?
is this possible to fit under the car?
(currently has d2 coilovers on it)
Old Feb 18, 2008 | 05:06 PM
sillyboybmxer's Avatar
you will need some serious fender work,...roll in the rear and lots of camber,...roll and pull along with a repaint if you in do that in the front or just get wider fenders
Old Feb 18, 2008 | 05:17 PM
iam7head's Avatar
Default Re: (sillyboybmxer)
why the heck you want spacer? spacers only will bump you out more.
35et is not really good, you'll rub like no tomorrow, can't run decent width tire and running on camber all the time.
Old Feb 18, 2008 | 06:24 PM
trbo's Avatar
My old S 18X9.5 +40 245/40/18 all around, front fenders flared/rolled, rears rolled and rear bumper screw moved and trimmed inside of rear bumper
Old Feb 18, 2008 | 10:34 PM
LAS2K's Avatar
Default Re: (trbo)
Yikes Paul...thats borderline VW vortex shizz right thur son.
jk
Old Feb 18, 2008 | 11:32 PM
eg6T's Avatar
Default Re: (LAS2K)
stretch the rear tires!!! cut/roll the fenders and youre fine,cut or tuck the front fender liner...dont run truck tires like trbo hehe
Old Feb 19, 2008 | 02:56 AM
high_revs's Avatar
crumdee!!!!!
Old Feb 19, 2008 | 03:22 AM
HondaKyle's Avatar
Default Re: (trbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trbo &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE> damn son!
Old Feb 19, 2008 | 04:26 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
Default Re: (eg6T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6T &raquo;</TD></TR><TR><TD CLASS="quote">stretch the rear tires!!! cut/roll the fenders and youre fine,cut or tuck the front fender liner...</TD></TR></TABLE>
or heres some better advice...
get other rims...
Old Feb 19, 2008 | 04:49 AM
i am taking s2killa's advice,
i think im going with the ASA AR1's 17x8 and 17x7
im not trying to extensively mod the fenders to fit my wheels
Old Feb 19, 2008 | 04:59 AM
S2KILLA's Avatar
Default Re: (projektcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projektcivic &raquo;</TD></TR><TR><TD CLASS="quote">
im not trying to extensively mod the fenders to fit my wheels</TD></TR></TABLE>
exactly... theres no reason to unless ur running extra rubber for track purposes...
wait for the right set of rims... youll be a lot happier on your decision...
Old Feb 19, 2008 | 12:58 PM
Default Re: (S2KILLA)
definitely agreed.
the ASA AR1's fit and look nice, going with 17x7 +48 and 17x8 +45
i can run a 225/ 45/ 17 up front and a 245/ 45/ 17 in the rear
the only thing is the 17x7's are on back order....
but i thought about it... can i just run 17x8 +45 all around?
Old Feb 19, 2008 | 01:22 PM
bky's Avatar
bky
I have a set of four 17x8+45 AR1, waiting for new tires. I have a 17x8+48 that fits flush, so I don't expect to have trouble with the +45. I'm only going to run 205 up front to give some stability to the non-staggered wheels. I'm lowered with rolled fenders. Sorry, I can't tell you for sure, but I will know in a couple months.
I do know that a 1" drop on a 17x8+48 -1 camber and a 225/45-17 doesn't rub, if that helps.
Old Feb 19, 2008 | 02:23 PM
Default Re: (bky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bky &raquo;</TD></TR><TR><TD CLASS="quote">I have a set of four 17x8+45 AR1, waiting for new tires. I have a 17x8+48 that fits flush, so I don't expect to have trouble with the +45. I'm only going to run 205 up front to give some stability to the non-staggered wheels. I'm lowered with rolled fenders. Sorry, I can't tell you for sure, but I will know in a couple months.
I do know that a 1" drop on a 17x8+48 -1 camber and a 225/45-17 doesn't rub, if that helps.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bky &raquo;</TD></TR><TR><TD CLASS="quote">I have a set of four 17x8+45 AR1, waiting for new tires. I have a 17x8+48 that fits flush, so I don't expect to have trouble with the +45. I'm only going to run 205 up front to give some stability to the non-staggered wheels. I'm lowered with rolled fenders. Sorry, I can't tell you for sure, but I will know in a couple months.
that helped me out alot. i think im just going to order 17x8's. thanks.
Old Feb 19, 2008 | 04:28 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (trbo)
18x9.5 with a +35?
at stock height and camber'd/rolled you could get away with it.
Old Feb 19, 2008 | 05:12 PM
B18C GSR CIVIC's Avatar
no if your gonna change wheels
be sure to do a 215 front and 245 rear, then run a 45 profile front and 40 rear so your sideall is the same size. You can do a 225 front but if your slammed and want less issues or having to bend that one tab,
Old Feb 20, 2008 | 05:01 AM
Default Re: (B18C GSR CIVIC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C GSR CIVIC &raquo;</TD></TR><TR><TD CLASS="quote">no if your gonna change wheels
be sure to do a 215 front and 245 rear, then run a 45 profile front and 40 rear so your sideall is the same size. You can do a 225 front but if your slammed and want less issues or having to bend that one tab,</TD></TR></TABLE>
im not trying to sound like a n00b here.... but if i run a 215/ 45/ 17 and a 245/45/17 isnt that having the same size sidewall???
Old Feb 20, 2008 | 05:37 AM
im not trying to sound like a n00b here.... but if i run a 215/ 45/ 17 and a 245/45/17 isnt that having the same size sidewall???</TD></TR></TABLE>
lol no
its a avg, basically your taking 45% of 215mm to make up your sidewall so on the wider rear you want less % to match.
thus 45% and 40%
Old Feb 20, 2008 | 03:03 PM
eg6T's Avatar
vaginas roll with high offsets...
Old Feb 20, 2008 | 04:38 PM
S2KILLA's Avatar
Default Re: (eg6T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6T &raquo;</TD></TR><TR><TD CLASS="quote">vaginas roll with high offsets...</TD></TR></TABLE>
and eg6t rolls with men
Old Feb 20, 2008 | 05:13 PM
trbo's Avatar
Default Re: (eg6T)
I concur..low offsets ftw
Old Feb 20, 2008 | 05:43 PM
eg6T's Avatar
Default Re: (trbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2KILLA &raquo;</TD></TR><TR><TD CLASS="quote">
and eg6t rolls with men </TD></TR></TABLE>
ahahah
Old Feb 20, 2008 | 08:21 PM
S2KILLA's Avatar
Default Re: (eg6T)
ahahah</TD></TR></TABLE>
i think ur the first person to not freak out about a gay comment... to you sir
Old Feb 20, 2008 | 09:08 PM
eg6T's Avatar
haha,np... i thought someone was going to flip out over that vagina high offset comment
Old Feb 21, 2008 | 05:47 AM
S2KILLA's Avatar
Default Re: (eg6T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6T &raquo;</TD></TR><TR><TD CLASS="quote">haha,np... i thought someone was going to flip out over that vagina high offset comment</TD></TR></TABLE>
haha touche
