is my motor pinging?
Old Feb 18, 2008 | 02:31 PM
zhan28's Avatar
Default is my motor pinging?
originally there was this rattling noise from the timing belt side, and the timing belt seemed to vibrate everytime this happened, it would happen when i accelerated from 1 to 2.5k and everytime the revs came down it would have a rattling noise also. so i changed the oil pump, water pump, and timing belt, and while the noise is almost gone there is still a little bit of rattling and the timing belt is still vibrating a little bit when the revs came down, but not close to what it was before, should i be worried about this and is this pinging?
Old Feb 18, 2008 | 02:38 PM
racebucket_eg's Avatar
Default Re: is my motor pinging? (zhan28)
What is your motor set up? Tuned or stock ecu?
Old Feb 18, 2008 | 03:01 PM
zhan28's Avatar
it is a lsvtec with chipped p72
Old Feb 18, 2008 | 04:25 PM
4g hatch's Avatar
Default Re: (zhan28)
what cams and pistons do you have.
also did you change the tensioner and spring
Old Feb 18, 2008 | 05:37 PM
PyroProblem's Avatar
Default Re: (4g hatch)
If you hear the SAME EXACT noise during acceleration AND deceleration, it is not detonation,ping,spark knock, etc.
It kinda sounds like your timing belt is slapping the timing covers. Id try and re-adjust your t-belt. Then rotate the engine and re-tention as the slack works its way out.
See if the noise goes away..
Old Feb 18, 2008 | 07:03 PM
zhan28's Avatar
yes it is the same noise and both during deceleration and the acceleration i can see the timing belt vibrating a little bit, i will definitely try yoru method pyro, thanks. i didn't think it's pinging neither it's just very annoying
ZurEnArrh
Jan 11, 2018 11:07 AM
Nutcase4life
Oct 24, 2007 10:48 AM
94hatchling
Apr 7, 2006 10:07 PM
Drew96EJ
Oct 30, 2003 01:48 PM
B_CRUZ!
Jun 24, 2002 10:57 AM
