idle problem
Old Feb 18, 2008 | 01:49 PM
xxh3iiraz0rxx's Avatar
Default idle problem
i been having this problem for several months my car idles fine till about the car warms up drops to about 500 rpms ans jumps to like 1000 i replaced iac valve just today becuase i thought that was it but it seems that it isnt can some one help me out im tired of wasting money could it possibly be the map sensor
Old Feb 18, 2008 | 02:44 PM
easycheese's Avatar
Default Re: idle problem (xxh3iiraz0rxx)
http://www.ef-honda.com/ben/Badidle.php
Hey i have been having the same problem, I'm gonna be working on it today.
since you replaced the IACV already i would check the FITV. Also you may want to flush your coolant, sometimes bubbles in the coolant will cause the FITV to freak-out.
I will let you know if i get the issue resolved.
Old Feb 18, 2008 | 04:19 PM
vannak_5415's Avatar
Banned
i have the same problem, it could be a vacuum leak, i replaced my hoses and it all goo now, try that
Old Feb 18, 2008 | 04:30 PM
B16COUPE94@AIM.COM's Avatar
Default Re: idle problem (vannak_5415)
TRY TO ADJUST THE LITTLE SCREW ABOVE THE THROTTLE BODY
Old Feb 19, 2008 | 04:30 PM
thanks a lot helped out alot
Old Feb 19, 2008 | 04:36 PM
4what's Avatar
if it keeps doing it, check and see if you have a vac. leak by, taking off you intake pipe. and starting your car, cover the TB with your hand, if the car turns off then you don't have a leak, if you car keeps running then you have a leak, just fallow the nosie and you'll find it good luck man
killahatch
Apr 12, 2009 07:44 AM
91EX4dr
Dec 6, 2008 06:30 PM
djviet2000
Aug 20, 2008 08:19 PM
redpeppers
Jul 26, 2005 05:10 AM
FOrSfEd
Mar 14, 2004 04:34 PM
