Integra sway bar in civic???
I have a 94 integra and was wondering if I can swap the sway bar onto my eg?? I know I would have to use the integra lower controle arms but would the sway bar bushing brakets bolt up to the eg chasis?? Any help would be great..
You need to take the following from your integra to make it work on your hatch : Rear lower control arms, Sway bar brackets ( they are bolted to the subframe ) D brackets, bushings and the bar with endlinks. Take one of the bolts that bolted into the subframe on the integra and go to lowes/home depot and get longer bolts, washers, lock washers, and nuts.
I did this on my 92 CX hatch , the sub frame on the hatch has the holes but they aren't threaded like the integra sub frame is.
